CREDA W200FW my machine keeps stopping mid cycle with the run and end lights flashing do you know what the problem is please
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
Creda excel W120VW the door lock light keeps flashing and cycle stops. If I hold the start button for a few seconds it starts again but then stops after about 2 mins.
From what you descibe it COULD be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 15, 2011 | Creda W120VW Front Load Washer
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Creda W200FW No: 45177606 washing machine have removed the PCB from a Creda W200FW washing machine and lost the info as to which plug goes where. Some are keyed and will only go on one place but some will...
Hi
I will try to help as best I can
  1. double red plug onto1x2 2
  2. double black wire plug onto 1x9 2
  3. blue black wire plug onto 1x11 2
  4. then 6 wire plug onto 1x5 6
This hopefully will solve your problem.
Please rate my solution.
Thanks.
Nov 11, 2009 | Creda W100FW Front Load Washer
I have a Creda W200FW. The rubber packing of the front door is full of black mold and smells bad. What kind of detergent is good to get rid of them. I have moved to a renging house and the washing machine...
Hi , Bleach will get rid of the black mold and stop it coming back for a while. Don't leave it on too long as bleach has a hardening effect on rubber. If you occasionally give it a wipe with a mild bleach based cleaner it will stop it coming back.
Jun 08, 2009 | Creda W100FW Front Load Washer
CREDA W200FW
DOES IT STILL HAVE WATER IN IT,IF SO IT COULD BE THE SUMP HOSE BLOCKED OR THE PUMPITSELF BLOCKED,OR THE PUMP MAY HAVE FAILED (LEAST LIKELEY)
FIRST DISSCONECT IT FROM THE MAINS,THEN
SHOULD BE AN EASY FIX,TURN THE MACHINE AROUND AND TILT IT FORWARD,REMOVE THE BACK PANEL AT THE REAR OF THE MACHINE,IF IT STILL HAS WATER IN IT THEN PUT A BOWL UNDER IT,AFTER REMOVING THE PANNEL YOU WILL SEE A BLACK HOSE WITH A JEWBILIE CLIP AROUND IT,UNDO THE CLIP AND SEE IF IT HAS ANYTHING IN IT (KIDS SOCKS ARE COMMON),IF SO REMOVE IT AND SECURE THE SUMP HOSE,IF NOT THEN THE NEXT THING TO CKECH IS THE PUMP ITSELF FOR BLOCKAGES,IF ANY FOUND THEN REMOVE THEM SECURE AND CHECK ALL PARTS ARE CORRECTLEY SECURED THEN TEST THE MACHINE,LET ME KNOW IF THIS SOLVES IT
Feb 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine keeps stopping
i bought a new washing machine but thanks anyway
Jan 22, 2009 | Creda W100FW Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
