Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
SONY DCR-HC40 CAMCORDER
Hello. I have this camcorder and the touchscreen is lit and buttons appear, but none of the buttons are working when I press them. The camera still seems to record ok, but I can't review tape, play, rewind or fast forward. PLEASE HELP!!! thanks!!
  • 10,594 Answers
Flexible wire connecting between LCD board and camera main board is cracked or broken and requires replacement.
Let me know to provide you part number of flexible wire if you want to replace it yourself.
Posted on Feb 02, 2009
DCR-HC40E camcorder error C:31:30 message. can you help?
reset the camcorder. (open the tape deck and you'll see a small hole that says reset on it) press and hold the button inside the hole for 3 secs. then also clean the tape head(the metal thing that reads the tape. with a q tip.
Sep 06, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Touchscreen wont work and can't get the calibration screen to appear as described in the manual. It keeps showing the initial date setup screen.
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced.
Oct 10, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
I have a SCR-HC40 handy cam. All of a sudden the infrared stays on even when night plus is off?
Correct model # is DCRHC40. please try to reset the Camcorder by pressing the reset button located near the handstrap using a sharp pointed object and try. If the issue persists, the camcorder will require service
Sep 26, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
Aug 25, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Touchscreen will not respond to touching screen
I have actually the same problem , I can see the pictures , buttons and all , just like normal , but the screen doesnt respont to any touch command .
Apr 03, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Document for downloading to laptop form sony handycam dcr-hc40
Check all updates and helpful news about DCR-HC40 on Sony Support.
You will get answers of many questions about this camcorder.
Jan 04, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony DCR-HC40 Viewfinder image is upside down
How did this happen?? I mean, all of a sudden you started gettin this image or after some repairs or you happen to drop the camera ??? pls specify.
Jun 20, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
292 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
