Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Want to ground tv to help stop dust
Whats the best way to ground the tv
    Scholar:
  • 50 Answers
The TV is already ground by being plugged in. Any appliance with current is going to have a magnetic field, and be prone to collect dust.I dont want to sound like some infomercial, but "periodic cleaning" is best, plus cleaning the dust filter on your central heating or air if you have it. You can find some anti-static spray cleaner for LCD's. Make sure you spray it on your lint-free cloth, not on the screen itself.
If you have carpet, it just makes it worse. Maybe you can buy one of those standalone air cleaners/deionizers that remove particles from the air for the room-- they sell them at bed bath and beyond and these places.
Posted on Feb 02, 2009
My fan wont stop running inside of my PS3 console. What is the best way to remove lint and dust from inside of my console? I would like to clean it myself.
Best thing to use for cleaning dust out of electronics devices is an air duster.
Example found here: http://www.maplin.co.uk/dust-and-dirt-removers-28999
You should be able to pick one up easily from a local computer or electronics store.
When you have it you'll just need to blast the air through some of the open vents to remove any built up dust.
Hope this helps.
Mar 15, 2011 | Sony Playstation 3 (PS3) Console
What is the best thing to clean the screen of this TV?
Use the cheap eye glass cleaner Wal Mart sells in the eye department.  Their cleaner is safe for glass surfaces, cleans real nice, and helps repel dust.
Oct 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Can ungrounded outlet cause damage to flatscreens?
If ever an energy pike occurs, it would most likely damage the TV for sure. A grounded outlet helps divert power surges to the ground. Sometimes grounded outlets can only handle so much overload, but never 100% guarantee.
Best protection for a flat-screen is a really good surge protector bar. The best ones cost about $100 - $150. Repairing a TV damaged from a power spike would cost about $400 - $600 from a TV repair shop. So, protecting the TV is a good idea considering the cost of repair.
Aug 27, 2009 | LG 42PX3DCV 42 in. Plasma EDTV
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Jul 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Chewing up Chain Drive
There is most likely a problem with the balance of the door. Release the door from the opener by pulling the red handle and lift the door manually. You should not have to apply more than 20lbs to lift it. When the door is at each hinge point and all the way up, it should stay by itsself. If it does not, the springs need to be adjusted or you will continue to replace gears.
Jan 22, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
My notebook is overheating
you need to buy a notebook cooling pad, if you don't have one on your laptop. this can help to reduce overheating of the laptop..
click HERE to see.
Jun 26, 2008 | Compaq Presario M2000 Notebook
Sony Trinitron 13 inch older model tv pops & smells at plug
If everything still works OK, then chances are the problem is even before the internal power supply. This could be a component that simply is nearing its lifeend such as a capacitor to ground, a VDR (voltage dependent resistor), a line filter (technically just a coil of wire), or limiting resistor in line with the degaussing coil. This should be a relatively easy/low cost fix and any qualified TV repair professional should be able to do the job pretty quick.
In some instances, there could be nothing wrong with the TV. It is also possible that the smell and pop is an HV (high voltage) discharge due to accumulated dirt, dust and grime anywhere near the anode cap (end od red wire to picture tube) or the FBT (flyback transformer).
Of course, the best would be to seek the services of a qualified TV repair professional since an onsite diagnosis would best serve your purpose.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 02, 2008 | Curtis CM13102 13" TV
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
