Check these codes. 0036/0065/0072/0049. If you wish to get more codes, check this link.
SOURCE: remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Let me know how it goes and please rate this solution
Lone99star
SOURCE: Emerson TV/DVD Model #: LD195EMX
check out this web site, it looks like what you're looking for
