Question about Canon PIXMA iP1800 InkJet Photo Printer
Resetting ink absorber on Canon ip1800
I've cleaned the ink absorber on my Canon ip1800 - filled with Canon's own blue ink! How do I reset it so that I can use the printer again please?
  • Anonymous Mar 24, 2009
    ink absorber.
  • 49 Answers
SOURCE: Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 06, 2008
  • 2712 Answers
SOURCE: canon ip2000 reset ink absorber
Waste Ink Counter Reset:
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanent
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
"After service mode Pls use software for permanent reset"
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Posted on Oct 03, 2008
SOURCE: how to reset canon ip1800
ink absorber is full contact service" ???????????//
Posted on Oct 10, 2008
  • 1342 Answers
SOURCE: Printers Problem Canon MP 145 code E27
Try this fix.....CLICK HERE
It works the same for the Canon MP 150 or MP 160
Posted on Jan 25, 2009
SOURCE: Reset Waste INk Canon MX318
help me please....!!
may printer error 5B00
Posted on Apr 01, 2009
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
Have problem with canon ip1800 refil black and color and everything sets and blinking orange 4 and green 1 time
acording to the canon led error codes, it means the absorber pad (for the waste ink, inside the printer) is full. you can try using this software tool to reset the printer or do it manualy:
  1. Press and hold power button with your finger and then take in power cable
  2. Hold power button, then press resume button with your middle finger twice.
  3. Let in power button
  4. Printer doesnot blinking any more.
  5. At this step you had done Manual Reset Step and printer could be use again.
  6. But if manually your printer still error, you should use Reset Software permanently
any way, your printer absorber pad /for the waste ink/ must be cleaned.
Sep 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full
Toclear blinking the ink absorber Full is Unplug the printer power cable. Then hold the power button, while the power cable plug into an electric current, press the resume button once (the power button is pressed ) emerging power button, until this process will be a normal printer, it can be used for printing.
Now you need to run software tools for permanent reset:
download in the canon printer section you will see Printer Canon iP-1880 Tools Resetting.
Run the tools and follow this steps:
1. Select USB port
2. Click lock release
3. Click ip1800
4. Click device id
5. Clear waste ink counter by clicking MAIN & PLATEN
6. Check EEPROM Box
7. Click EEPROM Dump
8. Test pattern 1
9. finished
Hope this helps.
Mar 30, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
The error "the ink absorber
Heres a link to your solution.
Hope this helps!
Feb 19, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My Canon iP1800 ink absorber is full.
The following reset method has tested and work perfectly to reset waste ink counter. Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
May 28, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Can I fix my full ink absorber myself? Canon iP1800
Only service centre can help you to replace the ABSORBER KIT.
May 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Canon ip1800, which keeps coming up with the message," ink absorber is full" Please advice how to sort this problem. Thank you
The printer counts the number of prints and cleaning cycles and when you get that error you need a shop to replace the ink absorber pads and reset the counter so the error goes away. If you bypass the error, the ink will fill up and leak out or ruin the printer sensors. The absorbers cover the entire bottom of the printer and require complete disassembly to remove.
Jan 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to remove ink in th full ink absorber?
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc) 2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3) 3. press 'resumet' ( the button below the power button of the printer) button twice... 4. release the power button 5. connect the usb cable of the printer to the pc... - a new canon printer shall be found in the list of printers. use it as default printer
Aug 07, 2009 | Canon PIXMA iP1800 Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset canon ip1800
Oct 03, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
410 people viewed this question
old marine
old marine
