Question about Amana ALG331RAW Gas Dryer
Timer Won't Advance in Auto Settings
When I set the dryer in one of the automatci modes the timer won't advance and the dryer just keeps running. If I put the setting to a Timed Dry position the dryer works fine and turns off whet it supposed to. I have already replaced the timer and that didn't fix the problem. Also, seems like the clothes are not drying properly. Vents and filter are lint free. Any suggestions?
  • Marc Shafer
    Marc Shafer Feb 21, 2009
    auto settings dont get hot or shut off , timed SEEMS to work ok
  • 177 Answers
SOURCE: My Amana Model NDG5800AWW dryer
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Posted on Sep 23, 2008
docjohn174
  • 943 Answers
SOURCE: dryer doesn't dry fully, doesn't stop
Hi .Thanks for the question .I would check the venting .Clean all vents to the outside clean all lint .save on hydro, as well. thanks the appliance doc
Posted on Sep 30, 2008
farfield
  • 462 Answers
SOURCE: Timer does not move in Auto/delecate
Im guessing there is another thermostat in the circuit to actuate the timer motor circuit. If you can find the timer motor wires check for voltage in the run (cycles yuor having trouble with) modes. Automaticadvance timmer mode is usually an open set of contacts and close when the element is heating too correct temperature allowing power to continue to the timmer motor. In the delicate cycle often it is the same thermostat on a differant set of contacts (but they could be on the same thermostat this type of thermostat has 3 termjinals usually 2 on 1 side and 1 on the other). that energize the timer motor.
The other thing that could be the problem is the timmer itself. There has to be a set of contacts inside the timmer that energize the timer motor in both cycles. these are or can work on some cycles but not others due to worn out parts in the timer. Check for voltages her that corrospond with your timer motor.
Hope this helps Please rate me accordingly and GOOD LUCK
Posted on Mar 09, 2009
  • 6 Answers
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Posted on Apr 25, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Our Amana Dryer is not drying clothes properly.
Hello there:
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
- If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 110 degrees and 150 degrees. Check that the drum seals are not worn out.
Posted on Dec 23, 2009
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
Aug 30, 2012 | Maytag Dryers
Timer won't advance on autosense,seems to work normally otherwise. timer advances fine on all other settings. was thinking it was the cycling thermostat, but the blower seems to be cycling. puzzled
when on auto the heat comes on and then shuts off and then the timer advances,when the heat comes back on the timer stops advancing,when on time dry the timer will advance no matter what's happening with the heat.next time send the brand name and model number so i can help you better,if it's gas you could have bad gas coils,you'll have heat for like the first 15 to 30 minutes then when the coils get hot they fail and no heat until they cool down,also if the vent line and the duct that the lint filter goes into hasn't been cleaned out the heat will shut down and if that happens the timer isn't gonna move.check that out and let me know what you find and send the brand and model number.
Sep 24, 2011 | Roper Dryers
My dryer quit heating and at the same time does not stop at the end of the cycle. Just keeps running. Is there something I can do to fix this problem?
If its on automatic cycle the timer won't advance if theres no heat. It will advance on timed cycle, though.
Sep 21, 2011 | Kenmore Dryers
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Timer does not advance, dryer keeps running.
in auto dry the timer motor receives voltage to advance by way of the cycling thermostat.[each time the thermostat opens to stop the heat the switch in the thermo then changes that voltage up to the timer and it will advance timer motor until it closes again for heat and this continues till clothes are dry]so as long as timer is receiving that voltage and not advancing then i agree its the timer.other wise it could be a failing/intermident cycling thermostat.a thought.in timed dry the timer motor receives constant voltage.so if never stalls in timed dry it may be a clue that the timer is ok. i hope this helps you understand whats going on. God bless ,tom
Jan 23, 2009 | Dryers
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Amana ALG331RAW Gas Dryer Logo
93 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
