Question about Brother MFC-640CW All-In-One InkJet Printer
Ink is full and color is not right
All the ink is full but the pictures are coming out almost like a negative
  • 1,602 Answers
SOFTWARE SETTING AND ALIENTMENT NEEDS TO BE DONE.
WHEN YOU GO TO PRINT SOMETHING SELECT PRINT THAN SELECT PREFERANCE
THAN SELECT MAINTANCE, TOOL OPTION,
LOOK IN PROFILE, LOOK IN EFFECTS ALSO
MAY HAVE SOME OPTION IN THE SETTING FOR YOU.
ROD
Posted on Feb 02, 2009
Hello, I have a HP Photosmart C6380 All-in-One printer and I'm trying to print colored pictures but the ink isn't working right. I checked all of the ink cartridges and they are all full and in their...
The ink-jets that shoot the ink onto the paper are CLOGGED.
Launch the HP Printing Assistant software, and run a "print-head-cleaning" cycle (or 2 or 3 cycles),
to try to unclog the ink-jets.
Dec 20, 2010 | HP Office Equipment & Supplies
When I try to print a picture from GOOGLE on my EPSON STYLUS CX5400the colors do not come out right. The pictures have a reddish tinge to them-not the true colors. I have done aboyt 12 HEAD CLEANINGS and...
> the cyan and yellow do not come up
You've either got clogged jets, or those two ink-wells are empty.
If running a "cleaning" does not improve anything,
then try replacing the ink-cartridge.
Oct 03, 2010 | Epson Stylus CX5400 All-In-One InkJet...
I am printing pictures on my Epson Pm260. The hair on all the pictures is coming out orange and ugly. What is wrong and how can I fix it?
Sounds like you are using a single COLOR Cartridge in your printer. If so one of the colors has run out and it needs that color to mix with the othe colors to produce the right hair color. Replace the color ink cartridge and it should work right again. Bud
Dec 06, 2008 | Office Equipment & Supplies
No real color picture, looks like an undeveloped negative, ghost
The pictures are indeed negative.  When scanning negatives or transparencies make sure you have the scanner set to the appropriate setting, otherwise simply Invert the colors in Photoshop, or similar photo editing software.
Dec 03, 2008 | Cameras
The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Nov 18, 2008 | Epson Stylus C84 InkJet Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not printing full picture.
Check your settings and make sure you are setup for the right photo paper if you are, then try updating your driver.
Nov 01, 2007 | Kodak EasyShare Color Photo Printer Dock
Pictures printing with stripes of color in some programs but not all programs.
Try new injet cartidges. If your printer has separate head and ink combo, replace the jets. The high quality mode operates the piezo jets at full power and lower setting can cause jets not to open as far. On some preinters, your particalar problem can be the result of too thin paper and the economy setting being used. Use 18lb or 20lb paper and see if it still does it on normal print mode.
Apr 27, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Brother MFC-640CW All-In-One InkJet Printer Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
