Question about Sony Playstation 3 (PS3) Console
PS3 won't connect. dns error
I looked this up on the net but i didn't find any case that fitted mine specifically. My PS3 is hooked up to my pc via ethernet cable there is no router in between it used to work but now it doesn't it keeps coming up dns error. It'll find the ip address no problem and i've entered the ip address manually the subnet mask the default gateway and the two dns's in manually i found them off my pc using ipconfig/all i'm not sure do i use the pc's ip address or the ps3's. help would be appreciated i am pretty sick of seeing this dns error come up. how do i solve it please. p.s the broadband i use is mobile broadband
  • 643 Answers
Put in this code at the DNS # 4.2.2.2 4.2.2.1 Good luck hope that helps.
Posted on Jun 02, 2009
My ps3 has an error 80710092 how do i fix it
  1. Change your DNS settings manually on the PS3 via XMB > Network Settings > Internet Connection Settings > Manual. Just allow the default entries until you get to dns, select manual and change it to 8.8.8.8 for the main dns and 8.8.4.4 for the secondary dns.
  2. Go to your router settings, select dmz and add your ps3 IP address to the list and select apply. You can see your ps3 IP address in XMB > Network Settings > Settings and Connection Status list.
  3. Change the password for your PSN account. The easiest way to do so it to log in via their website on a computer.
  4. Restart your ps3, sign in using your new password and you should be good to go :)
May 27, 2011 | Computers & Internet
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
When i try to hook up the ps3 to the internet it finds the IP but when it says connecting to the internet it won't connect it says that it is a DNS error? but i do not have any ethernet cables hooked up to...
check your pc they will be there Winxp users go to Control panel open network connections then open local area connection click on properties scroll down to Internet protocol (TCP/IP) hightlight it and click properties, your dns settings should be there!
Or Contact your service provider for the DNS settings!
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Dns error
For all those people getting error messages when trying to do the internet connection setup....
I had the same problem. I did a ipconfig/all on dos on my computer... found out all the numbers I needed to, and it would say ip address - sucessfull... and internet connection - An error occurred while resolving the name with the server (80710102).
So what I found out was to put in the IP address you find in ipconfig/all but add one to the last octive. Example if yours is 172.16.1.25... then in your ps3 type in 172.16.1.26
Then I was using the primary and secondary DNS numbers that my computer was giving me in ipconfig/all. Do not use those. For your primary DNS number use the number for your default which should be a right below your subnet mask number. For the secondary DNS number just leave it blank. 0.0.0.0
Then you have to upgrade to version 1.50 (which just came out yesterday actually). Get a memory stick with at least 100mb space on it. Make a new folder that is names PS3. Inside that folder make another new one that is called UPDATE. Both must be in capitol letters. Then go to PlayStation.com - PLAYSTATION®3 - Network - updates and click on "download now"... Then click save and save it to your memory stick in the UPDATE file, which should be in your PS3 file.
Then after all is done... plug that into your ps3 in one of the USB ports for the controllers. In the main screen go to SETTINGS and then go to SYSTEM UPDATE. Go to UPDATE VIA STORAGE MEDIA. PS3 will search for your media stick and it should say on the screen The latest update data was found... Version 1.50. Click OK and follow the rest of the instructions. After it is completely done... go back to the internet connection setup and go through all the menus to make sure all your numbers are the same as I stated above. Then at the end run the connection test. It should work!
I took me three hours of messing with mine before I figured it out so I figured I'd pass it along because I was on here forever trying to get it to work. I hope this helps!
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
No internet ?
When you connect your ps3 with a ethernet cord you need to restart your ps3 when its connected. If its wireless you may need to check your router settings.
Mar 05, 2008 | Sony Playstation 3 (PS3) Console
PS3 ETHERNET HOOK UP?
high speed whit al least 512 upload and download but conecting this to most linksys routers you will need to search the net there is a special commend you will need without your intervention the router is not compatible at 100% you will get a dns error look it up right here on fixya you should find step by step solution
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hook up to the internet
I have a problem. I have everything hooked up and when i go for a connection test it says my connection has failed because there is an DNS error. What is a DNS? and what do i have to do to fix it?
Sep 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
509 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
