The printer has slowed down a lot. It still responds properly in every other way and does a nice job. What steps can I take
SOURCE: hp psc 1315 driver
Heres the link , hope it helps , just click
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374568&lc=en&cc=us&dlc=en&submit.y=5&submit.x=3&lang=en&cc=us
temu,
Click here to get free driver and software from HP
Thanks
Iqbal
SOURCE: HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
SOURCE: scan from hp psc 1315 to Mac OSX
first remove the printers folder,then the drivers manually one by one from the receipts folder,then remove the hp software. Deselect the hp in the printer preferences and then install the hp software again. And then it should work. Check in the printer preferences for your printer, If the hp fax is in there. Remove it and select the printer and thats it.
1.printers folder is located on the hard drive-library-printers
2.reiceipts folder is located same-library-reiceipts
3.Download the software from hp website.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp psc all-in-one 1315.
Dear Sir,
Welcome back to Fixya
After changing ink cartridge,did you let the unit do an alignment? If not, you need to allow the unit to finish the alignment.If couldn't print another "alignment page" since the print queue was frozen in "pending" status ,so open the printer and remove and re-insert the ink cartridges.
Then place that "alignment page" on to the scanning bed and press the printer's scan button. The scanner startup again and 60 seconds later, then it start printing the documents remaining in the printer queue.
I think it deffinately solves your problem.If you have any problem regarding this issue leave a feedback we were happy to assist you.
Have a Nice Day!
Testimonial: "The information was helpful. (I had already done all suggestions. they are the solutions of choice.) Problem solved - but why?!!"
I have same problem, as it will print but one page typed can take 5-7 minutes ?
I have the same problem. The printer prints each line with intervals between them, so a simple page (e.g. in word) takes about 10 minutes to be done. I installed again the software from the HP page, but it doesn't fix the problem. Please someone knows how can I solve this problem?
do you perhaps have a setting somewhere that makes extra high quality? that slowed mine down to the speed of a paralysed snail
