Question about RCA HD52W58 52" TV
RCA-picture discolors, goes concaved
I have a RCA 52" screen tv that is about 3yrs. old. Lately, for like the first 10 minutes after turning it on the screen will flash a concaved look and the colors will be distorted. It flashes for about 3-4 seconds and then straightens out and will do it again in about a minute or so. It happens about 3-4 times each time the tv is turned on but then doesn't do it anymore until it's turned off and then back on. Any suggestions to what might be the problem?
thanks
    President:
  • 1,214 Answers
Sounds like a capacitor in the power supply is beginning to fail.Unless your good at this type of repair, I would call a tech to have it serviced. And I would also not use the set until the problem is corrected, or it could get real expensive to fix.
Posted on Feb 02, 2009
I was given a P52960 ,2002 rca 52 projection tv and the sides of the piture are concaved in.Can this be fixed easy enough,i am good with electronics/wireing..iI was told by the old owner that the solu
concave or bloated pictures on crt projection tv's are corrected with what's called a 'pincushion' adjustment. Look for it in the menu under video controls.
Dec 22, 2012 | RCA P52960 52" Rear Projection Television
I have an RCA 52" projection Tv, After it has been on for about 30-40 Mins the picture Goes concave.
Replace the deflection board. You can get a replacement board from www.tvrepairworld.com which also contains the Cd with installation instructions.
Jan 13, 2010 | RCA D52W19 52" Rear Projection Television
Concave picture
the convergence power supply module has failed
if you go into the menu you will not find convergence adjustments in the menu
the power supply module can be repaired
or you may want to get local help
if you want to try to repair you can get parts at mcm or encompas or tvrepairworld.com
Oct 26, 2009 | RCA P52937 52" Rear Projection Television
52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Aug 10, 2009 | RCA D52130 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA model P60812BL 10 years old picture goes fuzzy once on
Your convergence amplifiers are begining to malfunction. This is not expensive However I would advise that you get a qualified TV technician to work on the set due to a chance of damaging you TV if you install the amplifiers incorrectly.
I hope this helps
thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | RCA D52W19 52" Rear Projection Television
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
RCA P52937SG
ch over the power supply for the conv this is the stk730-020 that run your conv
Apr 15, 2008 | RCA P52937 52" Rear Projection Television
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W58 52" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
