Question about Canon PIXMA MX310 All-In-One Printer
The paper will not feed correctly. The Right side is getting jam
The paper is getting jammed on the right side of the printer.  This is creating the paper to feed incorrectly causing paper jams.
  • Anonymous Feb 03, 2009
    Tried to remove paper jam from front of the Cannon mx310.Paper tore leaving a strip of paper 9cms.x 2cms.inside the mx310.
    Alarm button and on/off switch oscillating.
    How to remove the paper,and return button/switch to normal mode,any suggestions would be greatly appreciated
  • brettrendle Apr 26, 2009
    Got a paper jam. Have removed the paper that i can see, but now the paper won't load. Keeps grabbing right side the alarm light goes on.
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Posted on Apr 05, 2009
My Brother 8480DN will not accept envelop
on most printers you have to reset the paper thickness for envelopes or it will read a jam
Jul 22, 2016 | Brother MFC-8480DN All-In-One Laser...
When feeding the paper into the printer, it gets sucked into the right side, jamming the printer and crinkling the paper. what does this mean?
Hi
kindly this problem caused because of problem in feeder rubber ...
please check that is run correctly and there's nothing jammed in printer clips or small peace of papers
Apr 25, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper feeds fine from the manual tray but the main tray (the bottom) I continuously get a paper jam. It begins to feed then jams. Anything I can do to fix this?
Dear,
No problem.I can solve your problem.There are printer has two paper feed system 1) manual feed2) on cassate.When you get a paper jam in cassate you clean paper clauth or cassate feed roller clean.Some times is missfed because it can not creat frashor in correct.Clean it then solve you problem.Or some of paper bit here.
Dec 09, 2009 | HP LaserJet 1320n Printer
Paper jams on right side when facing the printer
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to t
May 01, 2009 | Office Equipment & Supplies
Paper will not feed correctly
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 31, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Paper fed
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Canon PIXMA MX310 All-In-One Printer Logo
442 people viewed this question
old marine
old marine
