Question about Dell Latitude D610 Notebook
Dell Latitude D610 Laptop wont turn on
It wont turn on... i Tried everything it was working and now isnt the Screen stays black when i turn it on I need it thanks
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do the LED lights at least turn on when you push the power button?
Press the volume button and the power button at the same time. Hold them down untill the diagnostic program starts. Let it run it's course. It will stop on the problem. Fix the issue. I had the same issue. It was a simple world clock setting for me. Go figure?
Posted on Feb 06, 2009
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Mar 15, 2010
My dell d610 wont boot up,and screen stays black,but the power lite comes on,and the screen flashes real quick then goes black is there anything i can do?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 07, 2013 | Dell Latitude D610 Notebook
Black screen
1) Which software did you remove?
2) Is the machine running, but you just cannot see anything, or is it totally dead? Any sounds, humming, drives turning, lights flashing?
If it is not dead, try plugging in an external screen. To get the screen to work, you may have to press Fn5 I think (has a picture of two screens on the key). If the signal goes to the external screen, try pressing a couple of times more and see if it cycles back to the laptop's own screen. If the screen does not wake up, but the external one works, your screen needs looking at. If under warranty, take it back, otherwise it will be up to you to decide whether to spend on fixing it or splurging on a new one. You could of course just turn the laptop into a deskbound machine using the external screen, and spend the money on something else.
Sep 21, 2012 | Dell Latitude D610 Notebook
I am having more problems with my dell latitude D610. I finally got it going but now it wont let me go online at all and keeps telling me my proxy server wont let me connect. I have tried everything I know...
The laptop should have come with a recovery disc, just boot up and quickly press F2 or F8(depends on computer) and go to the boot menu, then select to boot from disc.
Jul 18, 2011 | Dell Latitude D610 Laptop Computer -...
My daughter has a dell latitude d610 and we can't get it to power on. I Have tried every trick I could find on the internet. This is what we have: green light comes on power supply and stays on, when...
You might want to check the ac adapter port.Plug in charger and wiggle it around,if there is alot of play chances are the connecting pins on the port have broken loose from the circuit board.replace port if necessary.
have you tried a different battery?
Jun 28, 2011 | Dell Latitude D610 Notebook
Dell latitude D610. Screen goes black. External Monitor OK.
Bob
Moderator
Thank you
Mar 15, 2010 | Dell Latitude D600 Notebook
Window wont boot on dell latitude d610, system restore, safe mode wont work, cant even reformate the commputer
there could be a posibility that the harddrive of the laptop is damage and needs to be replace. you already tried to reinstall the operating system but it still wont work in that case try to replace your harddrive.
Feb 20, 2010 | Dell Latitude D610 Notebook
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
Dell latitude d610 screen blackout all of a sudden and comes back to life after restart thanks for your help!
Check your power option. Under control panel. Make sure sleep or hibernation is disabled. Your laptop might be going into sleep mode making the screen black out and could not wake up from it.
Hope this helps
Dec 20, 2009 | Dell Latitude D610 Notebook
Dell latitude d610 dark screen
there is a inverter in LCd that makes your lcd bright white shine. when it breaks down you see black screen. something happens on lcd you cant see clearly  you should go to service and need to be changed INVERTER.
pls rate
May 28, 2009 | Dell Latitude D610 Notebook
Dell Latitude D610 Notebook Logo
3,259 people viewed this question
Alun Cox
