Question about RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More!
Rpm surge with intermediate power load
The generator ( yamaha ef2400is , new 10 hr use ) has a throttle surge (many times a minute) when under intermediate load >< 1000w .most annoying and dissapointing .
  • 2 more comments
  • ggsquiz Feb 14, 2009
    I have the same problem. I have had it back to the agent twice for inspections under load and they cannot find anything wrong. I pulled the side cover of and found the governor working overtime. The only time the gen set run good is under load, ie air conditioner etc.
  • corvette00 Apr 25, 2009
    I don't know if it is the same problem but it is similar. Mine I thought was related to the low oil shutdown system. The light flashes on intermittantly and at times quite often and even shutting down the unit at times. It has never been low on oil and overfilling it made no difference. However, if I tilt it by placing a 4x4 under one end or the other, it runs noticeably better. Is it the same solenoid problem or something else?
  • trederdb May 05, 2009
    My EF2400is has a throttle surge problem at idle. The more the load the better the throttle smooths to the point of no surge at all. It is worst when there is no load. I tried spraying the spindle of the solenoid with electrical cleaner as ggsquiz suggested but unfortunately there was no change to my problem - still there.
  • fishyme Dec 20, 2011
    Greetings from Alaska again.Using the tip from ggsquiz posted below I got some preformance.I have ordered and installed the part and now am working almost like it did when new 7 years and hunderds of hours of use ago.
    The part is called _____ motor unit assy _____7CF 81802 09 00
    It cost $73.00 from a Yamaha dealer only.
    Many may just need to clean theirs,simple things first.I run mine in temps from -35F to +80F for years.Mine was wore out,yours might get a little gummy if only used seasonal.SeaFoam your gas,clean your carb bowl,check your spark plug then as ggsquiz says clean your motor unit assy.I'm really really happy with my Yamaha.Good Luck
The problem is the governor and is easily fixed. Do the following: Remove back and side panels to expose fuel tank. Insert screwdriver into fuel on/off switch on front panel and remove. Now remove top panel. To do this unscrew fuel cap, pull out fuel spill surround rubber and remove top panel, just pull gently. Now with fuel tank exposed, remove retaining bolts. Gently lift tank and rest on frame. No need to disconnect fuel line.On top of carby is the governor, protected in a black plastic shield. Unscrew the retaining screws that hold it to the carby. Remove electrical connection and then remove governor from carby. Now remove cover by pressing on the three retaining plastic clips and prize upwards. Now the solenoid is exposed. Remove solenoid from its base by unscrewing the two retaining screws. Now that the solenoid is fully exposed use an spray on electrical cleaner that can be used on circuit boards. Spray the base of the solenoid in particular the spindle. Whilst spraying the spindle rotate it a few times until it moves freely. Then replace everthing in reverse order. Where the spindle exits the solenoid dust particles collect and increase the friction between the two surfaces. If you do not want to proceed as outlined tell your dealer it is the solenoid and have it fixed under warranty.
Posted on Feb 14, 2009
  • fishyme Oct 26, 2011
    Greetings from Alaska,Great tip ggsquiz.I use my 2400is as my sole power out here in the woods where I live.After 7 years I don't know how many hunderds of hours I have now but it is just that.Regular oil changes,SeaFoam once in awhile and use that ground wire, but that solenoid trick got me back up and running.I started small and after a few light cleanings I got some progress.Ended up soaking the solenoid for a couple of hours in electrical cleaner then letting it drain for a couple of hours.I have improved from nothing to surging at low power but can get higher loads up and running now.Any tips where I can buy a new solenoild would help.As I said,I've hunderds of hours on mine so might be time to replace this part.
Had the same problem on mine. Tried the Solenoid fix but didn't work. Took it to a lawn mower repair shop. They cleaned the carb for $55 and it runs perfect.
Posted on Dec 05, 2009
Lubing the solenoid as outlined by ggsquiz solved the problem I posted on April 25, 2009. It runs really well now.
Posted on Aug 06, 2009
Mine was doing the same thing and it turned out that one of the carb jets was slightly blocked. Once the carb was cleaned it ran great at low wattage but it exhibited the throttle surge problem at around 1500watts. The throttle motor assembly was diagnosed as being the cause. We'll see if that fixes this issue. Stay tuned
Posted on Aug 05, 2009
Yamaha ef2400is starts 1st time but revs out under no lad¬ generating full power
I went to dealer ,there was a loose screw for the voltage on the rev regulator internally
Feb 08, 2016 | Yamaha EF2400iS Portable Generator
Why does my Ryobi 2200 watt generator surge at low RPM's
Check for a weak or missing spring on the throttle linkeage.
Nov 17, 2014 | Electrical Supplies
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
How to fix surging on yamaha 2400 generator
If may be a partly blocked main jet ( Check by slowly closing the choke), if it the hunting clears out as you slowly close it it prob blocked main or pilot jet...
If the unit hunts (flutter)at 1/4 through 3/4 load, the governor damper spring on the throttle shaft under the stepper motor needs one more turn.. only after you've checker the carby..Only one turn or you will damage the stepper motor....one a few of these....
Jan 26, 2013 | RTO New Yamaha Inverter Ef2400is / Yamaha...
I have a yamaha EF2400IS generator that starts fine, but when i shut it down and try to restart it hot it will not start up again until it cools down. Please help.
If it doesn't start but turns over ok. It may be a problem with the magneto / wiring or spark plugs. It seems as though this unit has no automatic shut down. I would try replacing the spark plugs BPR4ES NGK or equivalent and gap to .030, oil 5/30 or 10/30 will do takes less than 1 quart, & air filter (basic tune-up) if not performed in some time. Yamaha recommends every 20 hours. Then try again. Here is a link to the owner's manual. http://www.poweredgenerators.com/yamaha/manuals/ef2400is.pdf
Jul 23, 2011 | Yamaha EF2400iS Portable Generator
1993 Yamaha XJ600 (pre divi) Mikuni carbs surging
Hi, Bevstait and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
New Seca II surging bogging under mid RPM load NOT CARBS XJRider com
surge at steady throttle
Yamaha FJ Owners Workshop Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Oct 03, 2010 | 1993 Yamaha XJ 600 Diversion S
My EF2400iS surges under low loads. Seems to smooth out with larger load. Any suggestions? Throttle motor or control box?
Idle speed screw may need adjusting slightly to increase idle speed. Also Main jet and Idle mixture Screws may also be out of adjustment
Aug 23, 2010 | RTO New Yamaha Inverter Ef2400is / Yamaha...
1000 watt Yamaha generator surges when on low setting
YOU PROBABLY HAVE LINKAGE PROBLEMS ON THE CARB IS IT AUTO THROTTLE IF SO YOU MAY ONLY NEED TO ADJUST THE SETTING SCREWS GIVE ME SOME DETAILS LIKE BRAND HORSE POWER CARB BRAND AND MODEL AND I MAY HAVE THE EXACT ANSWER FOR YOU I HAVE ALOT OF SMALL ENGINE RESOURCES FOR SPECS AND DIAGRAMS
Jun 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More! Logo
1,410 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Steve
Tom Chichester
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
