Question about Dell Latitude D610 Notebook
Screen Won't Turn On?
Ok, I was using my laptop i just got from My Uncle and it was working fine. Then i shut it off later. Later the next day i turned it on and it wouldnt fire up (the screen was Black) so i turned off and tried again No Luck so i kept trying and finally it worked
I wanted to noe what was wrong so i Asked my uncle he works for Seimens anyway he couldnt figure it out and now it completely wont turn on. Do you noe whats wrong with it and how i could fix it. Thanks
  • Ron
    Ron May 11, 2010
    Are there any lights showing, if you shine a flashlight from the top can you see anything?
  • 21 Answers
Using a flat edged screw driver, prise off the power bezel from the right hand side. Remove the two screws holding the keyboard in place, the gently lift the keyboard and unplug it from the motherboard. You should now see the connector for the screen where it attaches to the motherboard. Check that the connector is in properly. If this is OK and the screen still does not come on, you will need to remove the rubber stops from the screen and remove the six retaining screws. Unclip the bezel from around the screen and then remove the 4 retaining screws from the side. You will be able to lift the screen out and check that the cable connection to the rear of the screen is connected properly.
If the connection is good at both end of the cables then it's likely that the screen backlight has blown. These can be replaced by a professional for a modest cost or alternatively you will need a new screen.
Posted on Feb 06, 2009
Gas flow problem
It sounds like the solonoid valve is failing.
Aug 24, 2014 | Welding Tools
Compaq presario cq71 power indicator comes on for about 5 seconds then turns off without battery
cq71 check tips:
please clean memory stick pins and slots first if not ok, check next
1) plug in adapter to check jack led lights on or not, if no lights on no switch on.
2) if the jack lights on, then to switch on laptop, will be showing the more lights on, you are hearing cpu fan running. if nothing appear or every thing running with dark screen, or hard to switch it off go next
3) pull out the wireless card then switch on again, see what happened, if ok change a new card, if not ok, it is motherboard hardware issue
Dec 29, 2012 | Compaq Presario CQ60-220US PC Laptop
HP G61 511WM
When you wake the computer up from sleep, eventually some of the windows files become corrupted. I recommend that a proper shut down be done when not in use. Now to try and address your problem, do a system restore and take it back in time before this started, if successful should resolve your issues.
Mar 16, 2012 | HEWLETT-PACKARD Computers & Internet
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Shut truck off. come back later, and won't do anything, lights come on but no clicking at all. done twice to me. first time had towed. next day disconnected battery and hooked back up and it...
verify voltage and start signal to the starter when the truck won't start or click. most likely the starter solenoid has gone bad and will not engage the starter after the engine has warmed up.
Aug 12, 2011 | 2000 Chevrolet Suburban
My toddler started pressing a bunch of keys on the keyboard all at once and so I shut the laptop and when I went back later to try and turn it on it wouldn't go. I can't get it to boot up at all. Any...
Try restarten cpu,,k ,,imediatly press esc buttonn,,jus keep tapping it,,it should go to a boot option screen,,tell it to boot from hdd,,hard drive,,press the number that is next to hdd on screen,,ok should be good to go,,ok,,goodluck
Nov 09, 2010 | Computers & Internet
My HP laptop screen will not do anything. The first time this happened, I was in the middle of something and the screen suddenly became a bunch of black and white random-ness. I shut it down, and tried...
Perform the following:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If turned on, shut down the Notebook, insert the Battery and turn it on again. That's it.
Cause:
With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
Performing above procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
Aug 22, 2010 | Computers & Internet
Dell Latitude D610 Notebook Logo
198 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
