Question about Dell A920 InkJet Printer
Cannot figure out how to remove the ink cartridge from my A920 Dell printer, please help?
  • Dell Master
  • 2,404 Answers
Make sure your printer is on. on the front of the printer there is a place where you can lift up the scanning part, that should open up the inside of the printer and within a few seconds or so the cartridge tray should come to you and from there you can remove the cartridges.
Posted on Feb 02, 2009
My Dell A920 black Ink holder broken
call DELL technical support number and ask if there is available spare parts for broken cover replacement, you might end up replacing the whole ink carriage.
Jan 13, 2013 | Dell A920 All-In-One USB Color Inkjet...
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 11, 2011 | Dell A920 InkJet Printer
    My printer has been printing just fine until today. It still "acts" as though it is printing, but a blank page comes out. I have replaces both black and color cartridges and have shut down the...
    Have you tried running cleaning the nozzles using the software? Here is a link on how to do it:
    http://support.dell.com/support/edocs/systems/A920/a920en1.pdf
    just checking that you also removed any "tape" that might have been on the ink cartridges prior to installing them?
    Oct 27, 2010 | Dell A920 InkJet Printer
    My Dell A920 printer will not print the color blue. I've replaced the ink, 2 times. Changed the quality of print to "Best" and still get only the reds & yellows... Any ideas?
    hi there !
    -try the old cartridge if it will print the correct colour; the problem is the cartridge; otherwise it is the printer.
    cheers !
    Oct 24, 2009 | Dell A920 InkJet Printer
    Dell A920 cartridge stall error.
    Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
    May 30, 2009 | Dell A920 InkJet Printer
    DELL PRINTER A920 PRINTING IS BLOGGIE
    Hi! Your problem is your printers INK CARTRIDGE alignment, make sure that your printer ink cartridge is properly aligned. Or try to clean your ink catridge. GOOD LUCK. THANKS
    May 06, 2009 | Dell Inspiron 1000 Notebook
    A920 printer will not print in color & the cartridge is OK
    is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
    Feb 07, 2009 | Dell A920 InkJet Printer
    My a920 wont respond to anything
    Both. All inkjet printers are built to never run out of ink by no operating if one of the cartridges are almost empty or missing.
    Feb 03, 2009 | Dell A920 InkJet Printer
    Flashing Green Light/ Computer can't communicate with printer......
    Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
    If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
    Hope this helps.
    Dec 14, 2006 | Dell A920 InkJet Printer
    Dell A920 InkJet Printer Logo
    27 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
