Question about Olympus FE-170 Digital Camera
Cant download from my fe 170 to my pc
I plug camera in click ok for pc then get one moment for 10 seconds then goes black and nothing happens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Feb 04, 2013
SOURCE:
Iwillfixit4u
  • 20 Answers
SOURCE: FE 170 OLYMPUS digital camera
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
Posted on May 18, 2008
leecom72
  • 4806 Answers
SOURCE: My Olympus FE-170 won't connect to my PC
Hi there
Possibly not, try another camera lead in a different USB port.
If its the same format the camera card and try again, if you still get the same result, the camera is faulty.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
SOURCE: olympus fe-170 lcd display faints to bright white in seconds
you can replace the LCD screen for about 20 bucks.
Posted on Jun 24, 2009
  • 11967 Answers
SOURCE: How do I download pictures from my Olympus camera
Use a separate card reader to download your pictures.
Posted on Aug 28, 2009
  • 11967 Answers
SOURCE: I bought this Olympus FE-310 camera second hand. I
Use a card reader instead of the camera to download to a folder you create on your desktop.
Posted on Dec 28, 2009
When I connect my camera to the PC and select PC on the camera monitor then ok, the camera displays "one moment" and nothing happens. My PC does not recognize the camera
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jan 14, 2011 | Olympus FE-170 Digital Camera
When l connect my camera to my PC with a USB cable, nothing happens. l press PC on my camera and it flashes 'one moment' then stops. One moment still apperas on the LCD screen of my camera but nothing is...
Aug 09, 2010 | Olympus FE-210 Digital Camera
MY Olympus fe-170 has a broker screen, how can I get my pictures off of my camera?
Connect this to your computer via USB ..and wait.
Then press OK button on the camrea onece (this will "blindly" accept connection to the PC MODE)..
In a few seconds you will have a Removable Drive available in My Computer folder (Windows) or you will see iut on the desktop (Mac) ... Copy your pictures out of the DCIM folder to your computer ;-) ..
Or .. replace a screen ... I have a "parts-out" FE-170 with a good screen - easy to replace ... write back if you want it kriscichon@hotrmail.com
Nov 05, 2009 | Olympus FE-170 Digital Camera
I recieved an Olympus digital camera for my birthday ,a FE-170/X-760. It is supposed to have a USB cable included, it does not. How can I optain one?
They can be purchases at Walmart, Kmart, Radio Shack, etc. They are pretty generic...the plug that goes into your camera is the only difference...take your camera with you to get the correct size.
Sep 28, 2009 | Olympus FE-170 Digital Camera
I have a olympus fe-170 a got from a friend i would like to print
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Mar 27, 2009 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
143 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
