Question about Samsung Weather Resistant Security Camera SSC-12C
Slightly blured picture
Used cat-5e from camera to monitor should I have used something different
  • 74 Answers
USE A RG6 DUAL SHIELD COAX CABLE WITH SNS CONNECTORS WEATHER PROOF
Posted on Mar 09, 2009
    Genius:
  • 1,605 Answers
The best solution is coaxial cable. or shield CAT5 cable.
Posted on Feb 02, 2009
What is the best ethernet cable for connecting an estudio printer to a router?
You can use just about any network cable you have handy. Cat 5, 5e, or 6 will all work. Depending on your Toshiba eStudio model, your printer may support speeds of 10/100/1000Base-T. Cat 5e is generally the way to go these days as it supports the higher speed without paying extra for Cat 6 for a speed you don't need.
Sep 08, 2014 | Office Equipment & Supplies
Nss4000 with home computer quad core 2.4mghz 8 g ram. all rj45 connections are gigabit transfer speed between computer and nas is 11MB/s what should the tfr speed be? Should I be using cat 6...
Your speed is going to be limited by your slowest component. Most cables you buy in a store are really cat 5e which will do 1000Mbps. If your getting 11MBps (~100Mbps) then something in your network is running at 100Mbps. Assuming your going from Computer -> Router -> Nas
Computer needs a 1Gbps NIC in it, you need at least a cat 5e cable to router, router needs to support 1Gbps bandwidth, cable from router to nas needs to be at least cat 5e and your nic on nas needs to support 1Gbps as well.
So check the spec's on each device and replace the bottleneck because I doubt you can find regular cat 5 unless you tried really hard :)
If you can't find the specs comment back with all three model #s
Aug 17, 2011 | Computers & Internet
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
Rewiring a house putting in a net work for the future . what cable cat5e ,cat5e screened , cat6 , cat6 screened . would cat5e screened be better than cat6 unscreened ? cables away from mains ,
I'm guessing when you say screened and unscreened you mean shielded or unshielded. Shielded wire is used when there is a higher possibility of electrical or RF interference. In a typical household those type of interferences are uncommon. As far as the Cat.5e or Cat. 6 decision, Cat 5e is tested to 150 Mhz. compared to a 250 Mhz. rating on Cat. 6 therefore with future speeds in mind I'd go with the Category 6.
Aug 25, 2010 | Dynex 7' Cat 6 Network Cable - Gray
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
I want cataloge fore cat 5e
http://www.semitek.cz/tyco/fibre_optic/110c_enhanced_cat5_catalog.pdf
http://www.duxcw.com/digest/Howto/network/cable/cable6.htm
Hi Friend,
Here's the catalogue. The above links have information for cat 5e cables and cabling systems.
If you need any other info pls. feel free to contact.
Thanks.
Dec 23, 2008 | Superior Essex Marathon LAN Cat 5e Bulk...
How to wire up a cat5e faceplate with cat 5e wire
If you want to learn how to wire cat5e, here is a video:
http://www.serverracksandcable.com/cat5-cat5E-cat6-cat6A-cables-limitations.php
Mar 07, 2008 | Computers & Internet
Samsung Weather Resistant Security Camera SSC-12C Logo
192 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
