Question about 3Com NBX 3102 IP Phone
NBX 3102 Headset jack stops working
We have a call center and the headset jack stops working, you can hear, but the person on the other end can't hear you talk. Sometimes when you switch the headset to the handset jack it will work, other times both headset and handset jacks don't work. Most of the time it is that you can hear, but the other person cannot hear us talk.
  • 3 Answers
You should be using a plantronics a-10 interface cable if you are using hardwire headsets. get rid of the m-20 amplifiers. I support 280 of these phones and the best solution is to replace the phone. Power cycling the phone will help for a while but the problem will come back.
Posted on Mar 24, 2009
Dynex 18u headset not transmitting sound
Make sure your headset is properly plugged into the correct ports.
Make sure the volume is set to a medium level and is not muted.
Otherwise, I would recommend pursuing replacement options.
Feb 09, 2013 | Dynex - Universal Stereo Headset DX-18U
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
There is only one setting on my headset where there isn't a loud tone and the other person can barely hear me. They say it sounds like I am far away. What can I do to fix it?
The Plantronics S11 headset system needs to be plugged into the handset jack on your phone not the headset jack. There is a jack on the back of the S11 system where the curly cord from your handset will plug into. That should fix your problem.
Good luck from Headsets Direct!
Nov 11, 2010 | Plantronics S11 Headset
My m2250 attendant comsole give me a display message -3 2794 and when i see this mesage and calls comes in i cannot hear the person on the other end
You may be in the headset mode or your handset may be plugged into the headset jack, depending on the model of your phone.
Aug 13, 2010 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Speaker works but handset does not. replaced
Make sure to use a new handset cord as well. Also, make sure the handset is plugged into the handset jack under the phone. The 3102 phone has a headset jack that will not work with the handset. There is also a button mapped by default in the upper right corner that toggles from handset to headset. If the light is on, then it is set for headset and the handset won't work.
Dec 18, 2009 | 3Com NBX 3102 IP Phone
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Jun 25, 2009 | 3Com NBX 3102 IP Phone
My logitech headset was working and I was using it for a phone but now the audio is not working. I can hear them but they can't hear me. The red light is on the mic.
The red light indicates that the headset mute is on. Press the center insert on the right side headset and the light should go away and the distant end should now be able to hear you.
Jun 15, 2009 | Logitech ClearChat Pro USB Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
3Com 3102 unable to connect to NBX 100
The problem is licensing for a 3102 phone. I doubt an old NBX 100 has a group 2 license. The 3102 requires a license to run unlike the 1102 or 2102.
Jan 07, 2009 | 3Com NBX 3102 IP Phone
Is there a mute button on this phone?
Try using a headset temporarily.
If the headset works - then its a speaker problem that needs to be fixed.
You could get by with the headset while the service center gets you a replacement.
Jul 10, 2008 | Palm Treo 755p Smartphone
3Com NBX 3102 IP Phone Logo
314 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
