Question about GE Profile JTP18 Electric Single Oven
F3 code flashing
Anytime I go to place the temp to start the oven it flashes F3 Code... Help getting tired of Microwaved food...
  • GE Master
  • 3,361 Answers
Replace your oven temperature sensor.
F-3 bad sensor.
Posted on Feb 25, 2009
F3 error code
Bad oven temp sensor. If you know how to do so you can disconnect the power and remove the temp sensor. The two white wires to the sensor, ohm it. it must read ~1080 ohms. If not really close to that at room temp then replace sensor.
Dec 11, 2013 | GE Profile JT955 Electric Double Oven
My oven will not turn on. it was just beep and flash F3 what should I do
The F3 error code is usually for a bad oven temp sensor. You will need to disconnect the wiring harness for the temp sensor. Then take a reading with a ohm meter at both connections at sensor. You should get aroun 1100 ohms at room tempature. If the sensor is open(no complete signal) then it is bad and replace it. If the sensor tests good then it is a possible bad control board for range.
Nov 24, 2009 | Frigidaire Ovens
F3 and flashing on Kenmore oven
HI. this is a basic temp sensor issue. the oven control is programmed to cease operations if it dose not receive any resistance signals for the temp sensor during high heat situations.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 18, 2009 | Kenmore Ovens
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Get f-3 code after oven on for awhile
F3 is Open oven temperature sensor circuit, to fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Jan 02, 2009 | GE JRP15 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
199 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
