Question about Hotpoint FFU00 Side by Side Refrigerator
Model number Where do I find the make/model number so that I can install the ice and water dispenser?
    Genius:
  • 1,605 Answers
Usually it is located at either buttom corner. most likely the right buttom corner.
Posted on Feb 02, 2009
My sixth sense side by side is dispensing water but not making ice
Need that model number to give you correct model numbers. Because you dispense water does not answer why you do not have Ice. The dual water control valve has two sides one or the dispenser and one for the Ice Maker. Does the ice maker have any water in the ice slots? Fill slots with tap water does it dump when frozen?
Appliance 911 Sea Breeze
Aug 01, 2015 | Refrigerators
How to repair refridgerator ice water dispenser paddle
Not a person in this world can help you without a model number? If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 04, 2014 | Whirlpool Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispenser
Can you pull you refrigerator away from the wall and carefully remove the cover over the area where the water feeds the refrigerator. There should be a set of plugs one for dispenser and other for the ice maker. Make sure both sides are plugged into the dual water control valve. I did try to pull your model number up so I could help you better, but the model number above your post goes to an oven. Maytag and Samsung sometimes places parts in places that are hard to point out. Tis could also be a dispenser lockout. If you find the problem this would be something that commonly happens an assembly line. If you find the correct model number I will send you a service manual. Either way I am here to help, Thanks,Sea Breeze
Jan 17, 2010 | Samsung RF265AA Bottom Freezer French Door...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
GSS23LSTA SS WILL NOT DISPENSE ICE OR WATER
Open freezer door, pull out the ice bin, push and hold the door switch, and push on the ice dispenser pad / lever. The U shaped auger drive should turn at the back of the freezer behind where the ice bin was. I suspect it is not turning. If this is the case, you have a frozen auger motor. Just thawing it out will not permanently solve the problem, it must be replaced and a " boot " installed over it. It is important to know the exact full model and serial number, as there are several motors to fit various models.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint FFU00 Side by Side Refrigerator Logo
87 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
