Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus SX515W fitted new cyan ink cartridge printed 5 black text pages machine is now asking for new cyan cartridge tried jut keep pressing ok and removed cartage pressed ok then refitted cartridge still asking for new one even tried powering off at various stages can any one help thank you
3 Suggested Answers
SOURCE:
websnail
  • 419 Answers
SOURCE: My EpsonDX4450 won't print Black ink only when the Cyan is empty
Much as I'd love to say that Epson are being a bunch of "robbing gits" as you put it, in this instance they are actually helping protect your investment. If the printer was allowed to print without a valid ink supply on one of the ink types it would soon fill the printhead with either foam or air. Either promotes clogging. Now, whilst you might be certain that you're using just black, the printer may be programmed to use a small amount of the other colours (depends on the settings) so common sense often needs dispensing with. It's a pain in the backside, granted but it is intended to stop you from having much bigger issues later on. Appreciate that's not a "fix" but hopefully it explains why you're in the bind you are. My advice would be to purchase a cheap mono laser, especially if your printing it primarily of black text type... It's cheaper and you don't have to worry about consumables you don't use. Martin
Posted on Jun 11, 2009
  • 235 Answers
SOURCE: EPSON Stylus NX110 - 1st Ink Cartridge Replacement
you better have your printer check by a qualified printer tech thus avoiding any further damage to the printer the printer head is the most likely problem to
Posted on Nov 21, 2009
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Magenta and yellow wont print. new cartridges,black and cyan ok cleaned heads
All new cartridges loaded but no black printing. I changed the black cartridge with a second new one but still no black text printing !
Is this Epson 5800 printer a wtite off at this stage ?
John
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo PX800FW doesn't print text
printer working ok-did 50 colour photos ,6x4 when i made a mistake and pushed the print button when there was still about 1 inch of the previous photo still being printed.This print emerged with overprint of about 1".Thereafter the printer has refused to operate properly the next print being heavily discoloured.It then told me to replace the light magenta cartridge-this I did and the discolouration changed hew.It then told me to change the magenta and light cyan carts.-I did and discolouration changed again.It then told me to change the yellow and cyan=siscolouration now bright
red over coloured. I then successfully printed a letter in B&W proving that the black cartridge was still working.However as soon as I tried again to print a coloured photo it now tells me that the machine does not recognise the black cartridge and orders me to change it and until I do refuses to take any instructions telling me to install the black cartridge cprrectly.The black cartridge installed isout half full and has successfully printed copies and photos.I have carried out the suggested remedies by the machine and none were effectuve.How do it the infernal machine working again???
Oct 11, 2009 | Epson Office Equipment & Supplies
I have a Stylus CX5400 and can't get black to print without mixing blue into it. Tried new cartridges, same effect. On a text document the same lines turn blue everytime I print, the rest prints black. Any...
You may have a leaky blue (cyan) cartridge that has polluted the black output.
Well worth checking the inside of the printhead (where the cartridges are located) and see if there's a build up of ink.
Also, well worth checking that you haven't received an incorrectly marked cartridge that contains cyan instead of black ink.
May not be the direct solution but it will certainly help isolate a few possible causes.
Hope it helps.
Martin
Oct 01, 2009 | Epson Office Equipment & Supplies
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Red Light won't go out!
ok can u tell me what status monitor says?
Aug 09, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
