Question about Sony Xplod XM-554ZR Car Audio Amplifier
Storing memory on the sony xplode stereo
Permenant connection with the bluetooth car kit and the radio station
    Scholar:
  • 67 Answers
Make sure the yellow 12V Constant is connected to a wire with a direct connection to the battery. This retains your memory.
Posted on Feb 02, 2009
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
I have Tevion 43744 car stereo. No sound from radio and bluetooth doesn't connect. Are these issues related? What's the solution?
Could be some bad connections with the speakers; are you check this harnesses and wires?
Additionally, about the Bluetooth, accorrding with the Tevion 43744 User Guide... first will need PAIRING paorcedure. Press and hold BND/ID3/TEL button until the word "PAIRING" blinks on the display waiting for the bluetooth device to connect.
At this blinking time, please run the bluetooth search and connect function in your mobile phone. The car radio model no "BT Car Stereo" will be shown on the mobile phone . Select this car radio and connect. When you are asked for a connection password, please input "0000" in your mobile phone to finish the pairing, there is "PAIR OK" to show on the LCD. Then the bluetooth icon will be shown on the car radio LCD indicating that the bluetooth function is ready to use.
Hope this helps.
Aug 19, 2011 | Car Audio & Video
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
Stereo does not store adjusted audio settings and restarts after being turned off
Check to make sure the yellow from the stereo harness is connected to constant battery, connected to the battery, when the ignition switch is off, the yellow wire still has power. The yellow wire is for the memory for the stereo settings and radio station presets.
May 16, 2010 | Car Audio & Video
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony cdx-gt100 cd player radio stations are not storing,i have stored them all but as soon as you turn the ignition key,the stereo has lost all stored stations.thanks for any help
You will need to check the yellow wire of the stereo. This wire must have +12 volts even with the key off. Be sure it has a good connection.
Mar 08, 2010 | Sony CDX-GT100 CD Player
Connecting an MP3 player to car radio
The most common way is to use the auxiliary input of the deck or head unit. However I don't believe the JVC model you have has one of these. Don't despair though. Head to your local department store with a music department and pick up a universal FM modulator ($20-$30).
These will 'pretend' to be an FM radio station inside your vehicle. Attach the stereo mini plug to your walkman or other audio device (mp3 player etc.) Then tune the FM Radio to the fm station listed on the FM modulator and you will be able to listen to the device through your car stereo speakers. Now this isn't as clean as a direct hookup but for most its an economical way to listen to alternate sources on your Car Stereo.
Jul 07, 2009 | Sony Car Audio & Video
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
CK-7w mutes stereo
if cutting the power to the kit dont work try removing the radio and removing the yellow wire from the back for the radio (the one coming from the junction box of the kit). that should get the radio/cd working properly. inspect the wire and make sure its not earthing anywhere behind the dash. radio isnt realy that easy to take out if you dont know what your doing.
Mar 04, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
Does the unit need a permenent live supply
The car stereo he need it to store the radio stations and to start the cd in the last track he are playing,but he cames with a wire specifically for that always be a yellow one in most of the brands,and the red for the switch power.
Apr 13, 2008 | Car Audio & Video
Sony Xplod XM-554ZR Car Audio Amplifier Logo
63 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
