Question about KitchenAid KFP750 Food Processor
Kneading blade cannot be removed
The kneading blade got stuck to the processor after i knead some dough.It still works fine,but i cannot take out the blade.The blade turns around there,but doesn't come out.I knead most of the time and this hasn't happened before.Please help me.
  • 24 Answers
Plz contact 02223051554 / 23095757
Posted on Feb 03, 2009
2 Suggested Answers
  • 24 Answers
SOURCE: Kneading blade stuck
plz contact 022-23051554 /23095757
My pie dough comes out too soft and wet, what am I doing wrong?
If you feel dough being to wet, just add more flour a table spoon at the time. The dough shouldn't be too sticky. When making dough you can't always be followed exactly what the recipe says. Unless you're in a controlled environment like a baker has. Humidity and temperature play a big role. If it's to wet add more flour, to dry add a bit more water. but adjust only with tablespoon amounts.
Jan 08, 2015 | Food Processors
Unable to download Rhondo 2500 manual
the four pronged tool is a dough hook. Use this for kneading/mixing heavy dough, such as: white bread dough, pastry, etc.
Dec 19, 2013 | Food Processors
Motor keeps stopping
If you are making it do alot of work it may be slowing down enough to heat up. This will trip a thermal cutoff. Fortunately that one resets and you don't have to have an expensive repair. But now it may have overheated a few times and will start to burn off the varnish that insulates one winding from another. It will eventually burn out if you work it too hard. Can you get a more powerful one? Do you do this often?
Nov 26, 2013 | Magimix Food Processors
The motor stopped working i unplugged and replugged into a number of outlets...nothing happens is this a burnt out motor or could it be something simple?
Hi there, I just had the same problem and then found an on-line manual that says this:
An automatic, temperature-
controlled circuit breaker in
the motor ensures complete
protection against motor burnout.
If the processor runs for an
exceptionally long time when
chopping, mixing or kneading
a thick or heavy mixture in
successive batches, the motor
may overheat. If this happens,
the processor will stop. Turn it
off and wait for the motor to cool
off before proceeding. It will
usually cool off within 10 minutes.
In extreme cases, it could take
an hour.
Yayyy! Problem solved (I hope)!
Hope that helps you...
Nov 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Feb 02, 2009 | KitchenAid KFP750 Food Processor
Moulinox ovatio 3 dur - Pusher missing and need plastic kneading blade
Having contacted the Moulinex main office in Canada, I was informed that they do not ship parts to the US. However, they directed to the US sales office - contact "customer Service - Abtec Parts" <customerservice@abtecparts.com> who carry replacement parts for a large number of applicances. Hope this information helps someone in need. Thank you.
Sep 29, 2008 | Moulinex DG6 Food Processor
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
KitchenAid KFP750 Food Processor Logo
676 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Ross Keen
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
