TV No Volume
Olevia TV, some way a setting got changed in the menu and the volume does not work. It is connected thru cable box on (S Video) not sure if that is correct. Vol works for dvd not reg tv. Not sure is source issue or if an option was turned off in the menu option.
    Brigadier General:
  • 8,619 Answers
Hi!
Try retuning the tv channels again. Also check for a loose cable or a broken pin in s-video connector(s-video jack).
Thanks
Rylee
Posted on Feb 02, 2009
    President:
  • 2,110 Answers
1) Unplug all of the component connections from both ends
2) Reset to factory defaults
3) Plug only the green ends in, check picture... Hmmm, looks black and white
4) next, plug the blue in, check picture... a little blue/green
5) plug the red in, check picture.... still a little blue/green??
6) Unplug the red you just plugged in and switch it with the red Audio cable
7) Viola! great picture!
  • 10,594 Answers
Please check audio wires in TV coming from cable box as these seems disconnected and causing no sound in cable.
Restore sound on my Tv, suddenly lost.
  1. Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
  2. Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
  3. Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
  4. Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
  5. Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
  6. Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
Mar 10, 2015 | SEG 19 in. TV
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
My olevia tv volume only works with me dvd player but no sound when i connect my cable box
If cable from cable box is connected to TV, use TV remote to switch to Cable input if you have a Cable/DVR you will need to run speaker wires from Cable/DVR to a TV input
Nov 12, 2013 | Olevia LT32HVM 32 in. LCD Television
Hi, i was trying to turn down the volume on my tv (its an insignia) and i accidentally hit the channel button and i think it messed up the programming of my tv to my cable box. what should i do?
try setting the tv to channel 3 or 4. if that does not work, try finding a "input" or "source" or video" button on the remote and cycle thru them, this should get you back up and running. remember to have the cable box turned on during this so youll see when it comes back on.
Mar 24, 2011 | Televison & Video
I purchased wireless speakers and want to know how I hook them up so I can control the volume with the remote
Go to on screen audio setup, turn off the internal TV speakers to OFF, set the audio output to 'VARIABLE' (the audio line out signal at the TV RCA JACKS (RED & WHITE) will be controlled by the TV remote), connect a set of RCA cable from the TV AUDIO LINE OUT to the audio input of the wireless speaker transmittere box and set the volume on the wireless to about 1/2 way, you can change this later. Try it and see.
Dec 17, 2009 | Olevia 237T 37 in. LCD TV
My volume just shut down on me. how do I turn it
go into menu of tv make sure speakers are turned on--if you are using a cable box turn the cable box volume up-let me know if this helps you-djstvrepair@comcast.net
Sep 04, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
