Question about HP Compaq Presario V2000 Notebook
My laptop harddisk slowdown, it's a GQ laptop.
  • HP Master
  • 2,404 Answers
Go into MSCONFIG and disable all the startup programs then reboot and see if runs better, if it does then that means a program running in the background is causing the problem.
Posted on Feb 02, 2009
GET MESSAGE INTERNAL HARD DISK DRIVE NOT FOUND ON INSPIRON 1545.
Do harddisk is detected in bios setting if no?? so ur harddisk got crashed??and you have to replace ur harddisk
Sep 08, 2010 | Dell Inspiron 1525 Laptop
Hye..my acer aspire laptop very bad causes of virus infection and mess with all my files and folders. so, it think reformat is the best solution for me. But unlucky, when i restarted my Laptop and install...
Hello !
You have said that you have done installation and Harddisk are not recognised this is a indication of damaged Harddisk ie its registry is bad or its not working .
I recomend a new Harddisk then you will able to use your laptop
Before you change the harddisk you should check the IDE cables by swapping them coz sometimes they could be faulty, connect new cable to the harddisk then on it try installation again .
Good luck
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
How to open the power jack for GQ-zx 5361 laptop . and replace it with new one...
1.ESD wrist ********, connected to a good ground, work on a table.
2.Remove the AC adapter if plugged in, and the battery.
3.Completely disassemble the laptop, down to just the bare motherboard in your hand.
4.Use your soldering station, and I advise using a soldering wick instead of a desoldering tool, on the DC Power Jack leads. Works much better.
Remove the old DC Power Jack, being careful to not burn the motherboard, lifting the circuit traces, and rendering the motherboard useless.
5.Clean the DC Power Jack mounting area with Isopropyl Alcohol, and Q-tips to remove the residue. [WARNING! Isopropyl Alcohol is =>Extremely Flammable. I use the 91% Alcohol version]
Make sure the circuit trace mounting hole has a good tinned surface.
6.Install the new DC Power Jack in the circuit trace mounting holes. CAREFULLY apply solder to the DC Power Jack leads, and be sure to make good solder joints.
7.Reassemble the laptop
Sorry, I don't have access at present to Fry's GQ line of laptops for a Maintenance and Service Manual, to give you a link.
Aug 20, 2009 | Computers & Internet
My Hp Pavillion laptop dv2214tu doesnot boot beyond the HP INVENT logo page. I tried performing the Primary Hard Disk check as stated on the HP Support site but its not happening.I also reseated the RAM...
Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
Jul 09, 2009 | HP Pavilion Notebook
I need help on the GQ ZX-5361A drivers, pls help me
http://www.fryssupport.net/zx-5361A.cfm
they have support here for your machine...
Good luck, please leave rating , thank you kindly
Apr 27, 2009 | Computers & Internet
Cmos battery
visit youtube.com then search for laptop disassembly..
May 07, 2008 | Maxdata M-Book 1000T Notebook
HP Compaq Presario V2000 Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
