Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
GE Heat/Cool model AJHS10DCBM1
Sea Breeze: Thanks for responding. The unit is a wall unit and when the thermostat kicks the unit on it proceeds to make a loud squeal then produces a loud roar as it heats up the room. It kicks off once it reaches room temp specified, however, it continues to generate a roaring and an intermittent squeal.
  • GE Master
  • 4,655 Answers
OK I will be looking over the manual. Now that squeal sounds like the squirrel cage fan scraping the housing around it. Those units are so tight fit they can be twisted one way or tightened a little to much they scrape. I love them for there silence win they work right but hate them because my hand are too big to move things around inside them. Stay in touch I will be looking around while
multi-tasking today- I'll be here!
Posted on Feb 02, 2009
  • John Tripp
    John Tripp Feb 02, 2009
    I believe your fan motor has shaft play due to wear. When fan comes on the shaft moves in a direction that causes the fan blade inside and outside to rub and causes the squeal . The fan motor will need replaced to stop the noise.
Armstrong Ultra SX 80 Central Unit won't kick off heat setting
From what you describe it sounds like it might be a relay problem.
It needs to be diagnosed properly first.
Apr 21, 2017 | Heating & Cooling
Ge side by side freezer stays at 32 degrees
Look into the freezer at the rear wall for frost buildup as a layer on outside of that panel. Is the frost layer there? The most likely for temperature rise in the freezer and fresh food section of a GE refrigerator is a defective defrost control, defrost heater and defrost thermostat. The model number listed as your model on your post is not listed as a product sold in the USA. Can you find your model number printed around the fresh food section door somewhere?
8_28_2012_10_07_54_pm.jpghttp://www.geappliances.com/finder/trefrig.htm If you have other problems that you would like me to help you with please respond and I will be here to answer them for you. Should you find the model number please post the number and I will help you locate the parts and there location, Thanks Sea Breeze
Aug 28, 2012 | GE GSH25JFR Side by Side Refrigerator
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator and freezer does not cool. Can you sent me wirring diagram GE model HSS25IFMCC
Here is a link to a=> Service Manual It may not appear to be correct but it is. Now click here=> GE ARTICA PROFILE TECHNICAL INFORMATION Now pull away from the wall, unplug and remove the lower panel over compressor and then reach in and feel top of the compressor. Let me know if cool, warm or too hot to keep your hand there. These refrigerators are a little tricky when finding the cause of the problem but seems to always affect the motherboard=> WR55X10942_Motherboard While unplugged it does not hurt to remove the motherboard and examine both sides for burn marks or signs of heat damage. HSS25IFMCC_Back Either way I will be HERE or here on Fixya to assist you should you have questions, Thanks, Sea Breeze
Aug 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator side of a side by side not getting cool enough. GSS201EMDWW SD212874
Most times with that model it is the defrost heater and defrost thermostat that need replaced. Look into rear of freezer and see if a layer of frost is building on the rear wall. If yes unplug and manually defrost with a hair dryer and to the point we can remove the rear panel of the freezer to expose the defrost heater and thermostat. Tell me what you find, Sea Breeze
Mar 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is 65 degrees inside
We need to unplug and pull away from wall.I need you to check the top of compressor and tell me if warm, cool or too hot to hold hand there.There is also a possibility that the compressor start components failed and or the motherboard failed. I need you to confirm you model number and if correct we will proceed with repair. Thanks, Sea Breeze
Mar 18, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ge modle gsh22jfrecc is not very cold freezer fan works compresser fan works but i don`t think the commpresser is kicking on after doors have been opened .
Look for frost on rear wall of freezer. Yes? Unplug defrost and remove rear panel in freezer and use a hair dryer to speed thing up. If the defrost heater is burned out replace both defrost heater and defrost thermostat. I have been wrong I'm not perfect but that is my first guess. tell me if the model number is different than the one above your post and I will help you solve this, Thanks, Sea Breeze
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Dryer heats and sometimes doesnt heat
High Limit Switch, Thermostat are couple things to look for. If you could please locate the model number inside the door so I can help you better. Thanks, Sea Breeze
Mar 21, 2009 | GE Dryers
GE Room Heat/Cool unit will not heat with heat pump
If it was me I would cnage the sensor first. Simply because it is way cheaper than the control board and these sensors are fickle as hell to begin with.
Dec 14, 2008 | GE Zoneline AZ55H07D Air Conditioner
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
323 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
