Question about Frigidaire GLTF2940ES Front Load Washer
I have a frigidaire gallery washing machine that won't spin
My front loader [model # GLTR1670ASO] will spin as it should on occasion. Most of the time it will spin slow one way for a few seconds, then reverse spin slow for a few seconds. This happens on all wash cycles no matter what the speed is set at.
  • fordman968 Feb 03, 2009
    Excellent diagnosis!
  • 640 Answers
Defective motor control board..onthejob
Posted on Feb 02, 2009
  • onthethejob1
    onthethejob1 Feb 03, 2009
    i looked this up you under warranty,,check your owners manual..thank you onthejob
GE front loader spins slow
need the Model number to help you find the white tag and add the model number it inside the front door frame
Feb 03, 2018 | GE Washing Machines
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
Slow spin not working properly
IF THIS IS A FRONT LOADER CHECK THE REAR PULLY AND BELT.I HAVE RAN INTO A COUPLE PULLYS LOOSENING UP. IF SO REPLACE THE PULLY AND BELT. ALSO CHECK THE HOLES IN THE SPIN TUB,MAYBE A NAIL IS STUCK THROUGH ONE.GOOD LUCK!
Jan 16, 2010 | GE Washing Machines
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer: 4172952990. Does not spin. Clicks... at the beginning of a cycle it will spin for a few slow spins, then nothing. Had the Sears technician in. Said that it was the Speed...
Our kenmmore front loader is having a problem with the pump. When it empties there is dirt with the water. Is there any way I can get at the pump and clean it? It is working 70% and as long as I have the drain hose on the ground the water will drain. When I shake the hose dirt comes out and sometimes it says F21. Can anyone help.
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Front loader will not spin out cloths. Flashes errors sometimes.
Without the error codes in question it is impossible to help you.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 07, 2009 | Kenmore Washing Machines
Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
457 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
