Question about Toshiba Satellite A215-S5822 Laptop
SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
I am getting following error message in my Toshiba Satellite A215-S5822 Laptop:
(( "SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)"
WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent.
Press F1 to Continue ))
When I press F1, I am getting the error message as:
(( "A disk read error occured
Press Ctrl+Alt+Del to restart" )).
Please help me how to retrieve or format the entire Hard Drive.
  • Dan rogers
    Dan rogers May 11, 2010
    You are going to have to send the drive to a hard drive recovery specialist. You can get a list of local offices if you Google data recovery.
    As for the drive...it is junk. Time to get a new hard drive.
  • Joe Snide Jun 12, 2013
    is the computer itself still good
    Scholar:
  • 50 Answers
That will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
  • 1,602 Answers
WHAT TYPE OF HARD DRIVE DO YOU HAVE, IF YOU DO NOT KNOW, UNPLUG LABTOP REMOVE BATTARY, LOOK FOR THE DISC SHAPE ON A COVER 2-3 PHILLIPHS SCREWS REMOVE THE SCREWS, SCREW WILL STAY ACCACHED TO THE CLASTIC COVER, IF YOU STILL CANNOT SEE A NAME SHOULD BE A TAB OF SOME COLOR PULL JENTLY AND THE DRIVE WILL COME OUT THAN TURN OVER DRIVE AND YOU FIND NAMES NUMBERS AND LOTS OF GOOD INFORMATION FOR ME AND YOU TO KEEP RECORDS OF YOUR HARD DRIVE TYPE OF DRIVE DO YOU HAVE...
GO TO ADDRESS BAR AND TYPE IN
SMART FAILURE HAR DDRIVE
AND YOU GET ALL THE INGO YOU NEED ON THE SUBJECT.
IT CAN BE HARD DRIVE, THE BOIS ON THE MOTHER BOARD, THE SOFTWARE PROGRAM THAT WROTE ALL THE INFORMATION TO HARD DRIVE.
THIS IS A BIG PROBLEM FOR YOU
ROD THE CANDYMANGNADY
SMART failure predicted on Hard disk 4 Toshiba: MK2035GSS-(S1)
unless you have an operating system disk a new hard drive will do you absolutely no good .
Dec 14, 2015 | Toshiba Satellite A215-S4747 Notebook
My Toshiba satellite with a mk2555gsx won't boot up no messages, tried recovery discs to no avail.
SMART FAILURE PREDICTED on HARD DISK 2: TOSHIBA MK2565GSX-(S1)
Warning: Immediately back-up your data and replace your hard disk drive.
Press F1 to continue.
What is that problem?? and how to troubleshoot this my computer, the model is neo M1110 noteboke.
Sep 10, 2013 | Toshiba MK2555GSX 250GB SATA/300 5400RPM...
It means pretty well what it says.
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
hope this helps
Oct 08, 2012 | Toshiba Satellite A215-S4747 Laptop AC...
Smart failure predicted on hard disk 4 toshiba MK1032GSX-(S1) press F1 to continue
You may continue on and boot the system.
However it is time to backup the data on that drive and replace it.
the S.M.A.R.T system is a warning.
Sep 07, 2011 | Toshiba Computers & Internet
SMART Failure Predicted on Hard Disk ....What do I do????
Get a new harddrive and clone the old one before it fully fails.
May 26, 2011 | Toshiba Satellite A215-S5822 Laptop
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
Toshiba Satellite A215-S5822 Laptop Logo
6,929 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
