Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
I have a Samsung side by side refrigerator RS2533SW and it stoped cooling both sides. I already tried to reset it. That did not help the fan is kicking on an off. Do you have an Idea. Thanks
  • Todd Born
    Todd Born May 11, 2010
    is the compressor coming on? it may be off on overload.
  • 5 Answers
Check PTC on compressor. Should show low resistance when cool, ussually about 25 ohms. When it works properly it will switch from a start/run (25 ohms) to a run (10 to 15k ohms).
Posted on Nov 04, 2012
  • 700 Answers
Check to see if the fan and compressor in the back conme on first. if they do then shut the unit off and remove the back panels inside and thaw out the ocils.
Posted on Apr 05, 2009
  • Todd Born
    Todd Born Apr 05, 2009
    check toi see if the coils ar efrozen up.
  • Todd Born
    Todd Born Apr 08, 2009
    check the circut board in the very back for a bad connection.i
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2533SW refrigerator is not cooling, freezer is working well. how to fix the problem. don't say unplug, I already tried many times for unplug for 15 seconds, 2 minutes, 2 hrs and overnight. The...
If your seals are good on the door and the fridge side is set for a mid range temp ck and make sure the fan is running in the fzr side. The fridge side steals cold from the freezer by directing air from the fzr to the fridge. Also make sure the fzr does not have an ice block in it the back will be frosted up and if you took the back shell off you would see the cooling coils frosted up real bad or even iced if you find this your refrigerator is going to stop working soon. The suspect parts are the defrost timer the heating element in the freezer located with the cooling coils and the defrost limit this is a nickle size disc with one wire running to the end of the heating element it kicks the element on and off to keep it from overheating the fzr. The defrost timer is usually located in the fridge side under the top or backside plastic it will have a slot in it that a flatblade screwdriver will fit it and you can turn it with audible clicks It kicks the heating element in for a few minutes each day if it quits it will not advance. Hope this helps all of the parts can be purchased and installed by the home owner good luck and remember to unplugg before delving into the elect parts.
Aug 16, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Dec 02, 2007 | Refrigerators
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
370 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
