Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Need to locate belt to replace on GE stackable washing machine
Where can I view a detailed manual on getting access to the belt?
  • daredevil196 Feb 14, 2009
    I have the same request
Where is belt on ge washer stackable unit 2005
Posted on Oct 24, 2011
How to dissasemble GE model wsxh208a1ww
log on to find your make ,model and they will give you step by step instructions on the repair. the site also includes pictures of every detail. good luck ,Steve
Oct 15, 2012 | GE WSXH208A Front Load Washer
Install dryer belt any tricks to make it simple on a GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer
Nothing on a stackable is easy to replace and no tricks so just take your time and you'll get it on.
Sep 27, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Where do i check to see if the belt needs replaced. I have a ge washer model number WJRR4170G1ww
You will need to remove the FRONT panel of the washer to access the interior so you can view the drive belt. Some of these panels come off by locating two retaining clips (each one about two inches on from each side) in the seam where the top meets the front panel. Use a putty knife to push in to release the clips and the panel should come off. Or, there may be two screws located at the very bottom of the front panel that you will need to remove. The following link has a helpful diagram to assist you:
The drive belt is located at the very bottom of the cabinet under the wash tub. Check the belt for obvious signs of wear, cracks, or breakage. If you have any questions, please post back and let me know. I hope this helps you.
Aug 03, 2011 | Washing Machines
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
I need to replace the belt on my Miele washing machine. Can you tell me how to do it?
Open the washing machine's back access panel.Depending on the make and model of your washing machine,you may need a screwdriver to unscrew the screws that hold the panel up.Locate the washing machine's drive belt.It will be in clear view,detach the old drive belt.Use the screwdriver to unscrew the pump coupling.Then gently slide the old belt off of the drive belt notch.If the belt is broken,be careful not to leave any pieces in the washing machine's interior. Slide the new washing machine drive belt over the drive belt pulley in the machine.Carefully stretch the belt up and over the second pulley before releasing.Use the screwdriver to re-attach the pump coupling.Test the drive belt's tension.If it is looser,tighten the pulleys to increase the belt's tension.Replace the access panel and resume using your washing machine.
Aug 27, 2009 | Miele Washing Machines
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washing machine leaks
GE Profile stackable washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 29, 2008 | GE Profile WPXH214F
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
340 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
