Question about Nyko Net Connect For Nintendo Wii
I don't know how to hook this up
I bought a cat 5 cable but need to know where to hook it up on the computer.
  • zack1211 Feb 08, 2009
    help hook up
  • 132 Answers
You plug it into your modem or your router not your computer.
Posted on Feb 19, 2009
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
How do i hook up my linksys wireless-g broadband router wrt54g-someone disconnected it
Disconnect the power to each unit (except computer, shut it down). After you connect the modem,router and computer, power up the modem,then the router,then the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Hook it up per this diagram:
May 20, 2011 | Computers & Internet
I have 10 computers and 2 printers networked in the office. I'd like to hae them all wired. I bought a 10/100 switch but not sure how to hook it up with my router. Any advice?
Most low to mid range switches require no configuration. Switch-to-router connections use a standard straight-through CAT-5 network cable, same as for your PC. Connect any switch port to any LAN port on the router (you didn't say if your router has more than one) and then connect your PCs and printers to the other switch ports with CAT-5 network cables. The WAN port on the router remains connected to the upstream (Internet) provider.
Feb 19, 2011 | Computers & Internet
I have two computers. One is connected to the internet with a cat 5 cable. I bought a new cable for the new computer which is a fastcat 5. However, I cannot get this computer to work on the internet. If i...
I'm assuming that you have a modem or a modem and router combination with multiple cat5 ourputs. You have tried both computers with the Cat5 cable and they both work fine. If this is the case, I would suspect that you have a faulty fastcat 5 cable.
Feb 14, 2011 | PC Connection FastCAT 5e Patch Cable...
Can't figure out how to hook up my WBR-2310 to my laptop
1:get a Cat 5 e cable 2:plug it into the port on the back labeled WAN 3:plug the other end of the Cat 5 e cable into the internet 4:turn your laptop on 5:go to wireless networks 6:choose your wireless router,have fun 7:do what you want on the net!
May 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have hooked up the wires correctly and I keep getting an error message stating that I have not hooked it up correctly.
well to hook up a wifi router, u connect the cat 5 cable from the internet port on the router to the cable modem and u coonect your computer to any of the open ports.
Sep 21, 2009 | Linksys Wireless-G WRT54GS Router...
Where is the cap 5 cable located?
The Question is not clear. Pls be more specific
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I HAVE A LINKSYS WIRELESS-g 2.4 BROADBAND ROUTER, 54MBPS. HOW DO I HOOK IT UP TO A MOTOROLA S85101 CABLE MODEM? I KNOW NEXT TO NOTHING ABOUT COMPUTERS
Your router had a outlet marked Internet. You need a CAT 5 cable to plug into that outlet. Plug the other end into the same kind of hole on your modem. make sure your cable is connected. Turn on or plug in your modem. Count to 30. Plut in your router. Count to 30. Turn on your computer. Wait for it to boot up. Use the wiundows wizzard to setup your connection.
Sep 07, 2009 | Linksys Wireless-G WRT54G Router
Connection
Go to this site to download a manual to verify you have it setup right.
http://www.d-link.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
or try this first.
Power off your modem,D-Link and PC.
You need to have the cable that looks like a wide phone plug with 8 contacts instead of 4 (cat 5 cable) go from your comcast modem to the plug on back of the D-Link that is marked WAN.
Then plug a cat 5 cable into any of the 1 through 4 Lan ports on back of the D-Link to your PC's Ethernet port.
Then with all these powered off turn on the Comcast modem, wait a full 2 minutes for it to settle in. then turn on the D-Link give it 2 minutes then turn on your PC.
If that doesn't work for you refer to the manual or you have something broke that may require servicing in person by someone computer savvy.
Hope this helps.
Jul 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Hookup westell modem to belkin wireless router how to
Telephone cable from wall to modem..Cat 5 cable from modem to Router...You will have to also get another Cat 5 cable for initial set up an hook it from the router to your PC..That is so you can get into the Router software and set your settings, such as network name and encryption. Once the settings are completed then you will have Phone cable wall to modem, Cat 5 from modem to Router.You can unhook the cable you initially had from the router and your PC...if you have any questions just let me know..
Pls rate this solution.
Apr 29, 2009 | Belkin (F5D7231-4) Wireless Router
Nyko Net Connect For Nintendo Wii Logo
136 people viewed this question
Top Nyko Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Nyko Video Game Console and Game Expert? Answer questions, earn points and help others
