Question about Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier
Heating does not work in Danby 3-IN-1 Home Comfort Unit
I purchased a Danby Model Number DDR556RH, Serial Number 0108070702122 from Compact Appliance in Richfield, Ohio, on 11-5-08. The heater does not work, and I do not know where to take it for service. The Danby Web Site was absolutley no help, and I was on hold on there customer service line for over 45 minutes, before I hung up. Can you help. Thank you.
Greg Whitman
Trappe, Pennsylvania 19426
Called Danby, and the Unit is under warranty. They gave me the name of someone local who will fix the unit under warranty. The only problem is contacting the person. Voice mail is full.
Thank you
Posted on Feb 03, 2009
I have an aprilaire model 6303 control panel, and the B and G terminal lights are on, on the equipment output and the fan runs continously. Is the board bad or what please help
[PDF]Aprilaire® Zoned Comfort Control® Product Guide
ftp://ftp.aprilaire.com/...Control/5050_ZCC_productguide.pdf
AprilaireAprilaire Model 6303 Control Panel ... with the Model 6504 Intelligent Zoned Comfort system, we have the right control for your ... A control panel coordinates the operation of the equipment with the ..... Proper control of the fan (G-terminal) for either electric.... Auxiliary output relays available to control humidifiers, electronic.
[PDF]Safety & Installation Instructions - Aprilaire
ftp://ftp.aprilaire.com/Fulfillment/Inbox.../6404_install_guide.p...
AprilaireModel 6404. Zoned Comfort ... Do not mount the control panel on any part of the heating/cooling equipment or ... allowing for control of a humidifier. b. HUM LEDlights when the relay is closed. .... on the fan (G output terminal) with a heat call (W1output ..... Run wire between the HVAC equipment and the control panel. 3.Missing: 6303
Jan 20, 2016 | Aprilaire Humidifiers
I need the air purifier filter for a danby dhcc6020
You may be able to use filters from the stove overhead filters.Stove suppliers sell filters which can be cut to size.
The filters are usually the same as those used for air conditioners.
Feb 02, 2013 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Looking to download a danby humidifier manuel model DHCC6020-1
nursechris - The following is a downloadable and printable link to the owners manual, you're looking for.
Take good care of your Home Comfort Dehumidifier, as it has been discontinued by Danby.
http://www.beveragefactory.com/images/dhcc6020_efom.pdf
Hope this helped you & thanks for choosing FixYa.
Sep 11, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Will not **** up water seems to be air coming out from the side with a tiny bit of sprinkles
From what you have described, according to the Owner's Manual for your "Retired" (that's Danby speak for "Discontinued") model, the air intake filter needs to be cleaned. As not enough air is being taken in, so the fan can operate properly.
In case you have misplaced your Owner's Manual, I have included a link to it that you may download and print for future reference. http://www.danby.com/cms/uploads/products/en_manual/DHCC6020%20EFOM.pdf
I hope this has helped you and thanks for choosing FixYa.
Aug 18, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
Need a manual for Danby PHD DHCC6020...how do I get the dehumidifier to work??
Are you sure you have a Danby Humidifier and not a Dehumidifier? As Danby doesn't make humidifiers. At least, not in the US and Canada.
Please advise. Thanks
Apr 28, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I got E4 error message, and my tank is empty. The humidity value blink too... What can be the problem?
There is some type of electrical component that needs to be replaced called a relay switch. I had the exact problem and it was only a little over a year old. I am not impressed with the appliance for the price i paid for it. I went and bought the cheapest dehumidifier I could find and it works great. You can bypass this problem on your home comfort system by attaching the hose that came with it to the back and the machine will work the water will drain out of it. I
Apr 07, 2010 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier Logo
179 people viewed this question
Top Danby Humidifiers Experts
Paul Carew
Dennis
Are you a Danby Humidifier Expert? Answer questions, earn points and help others
