Question about Jack Lalanne Health Master 100 8-Speed Blender
The gear on bottom of container that ingages motor leaks grease into contents of container.
    Problem Solver:
  • 5 Answers
The company that is responsible for the healthmast 100 is: http://www.tristarproductsinc.com/about_us/welcome.html
Posted on Apr 16, 2009
My blender leaks at the bottom
needs new gasket or container,is it cracked?
Mar 12, 2015 | Blenders
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
Soup mate pro won't start
try powering off, removing contents from the container, refill using less contents and push the contents to the bottom plate. Turn power on. If beeping stopped it will work. Another thing to try is turning the rubber gear on the base or bottom of the container slightly then put container back on the base, as before do this while power is off at the power point for safety. Regards Greg T. My mother bought one and Ive had to step in as Im the only one to make it work. Hope this helps you. I am about to go past for the 3rd time of her using this device to see if I can help do a re-heat as she made a soup and its now not playing ball again 4 her. Forced to contact the distributor of course!
Jan 09, 2014 | Oster 6678 14 Speed Blender
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
Our wet container smoked and smelled, the taste of plastic got in the shake..There is no "visible" trouble Do you think it could be just the agitator or do you think it could be the motor Model 5000
first take off the container and on the under side bottom of it that sits in the unit is a drive gear see if you can turn it with your fingers also at the bottom of the wet container inside it is a blade that spins in a bearing and this bearing gets tight or even seized up at times strip out this bearing and renew it and the seal but watch your fingers as the blade is very sharp rap it in a thick rag to hold it in your fingers,,,,
Jun 06, 2010 | Vitamix 5000 Work Top Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
Jul 21, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Jack Lalanne Health Master 100 8-Speed Blender Logo
416 people viewed this question
Top Jack Lalanne Blenders Experts
eyecam
Are you a Jack Lalanne Blender Expert? Answer questions, earn points and help others
