Question about Dell DJ MP3 Player
My dell DJ has a harddisk problem, or so it tells me. It is stuck in recovery mode, even when I reset it. The 'Clean Up' option pulls up a window that says 'Scan Disk..." but then just returns to the menu. Dell customer service refuses to help me out because my service tag doesn't register on their computers. What do I do?
Try to see if you can upgrade the firmware...mine did this so i upgraded to the latest firmware from Dells website. It actually had the upgrade already- but it formatted the drive & fixed the problem. Luckily i keep a file backup on my pc so i didnt lose anything with the format. It worked for me, so it might be worth a try for ya; if it doesnt- well ... i found several 20 gb DJ2s on line for like 50 bucks. would problably cost you more than that to fix the one that you have- just a thought
Posted on Feb 19, 2009
Stuck in windows error recovery window
to get into safe mode, turn on your computer and press F8 immediately. Press the F8 constantly, till the safe mode booting option will come up.
Pressing F8, is the sure way of make your computer enter into safe mode.
Good luck.
Apr 16, 2010 | Dell Dimension 4600 PC Desktop
I have a dell 1525 inspiron when i turn it on it says windows error recovery when i try to start the computer it goes to windows boot manager it says insert your windows installation disc and restart your...
For that First when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd or dvd rom then save settings and exit.
Then it boot with your recovery disk.
Then follow the procedure and enter in recovery console mode.
Then type in prompt "chkdsk /r"
then press "y
then it fix error on harddisk.
Then check if still same error then again boot with disk then repair your windows .
Let me know if you need more assistance.
Thanks.
Oct 10, 2009 | Dell Inspiron 1525 Notebook
My dj is stuck on DELL screen,,won't shut off or tried restarting it ..that doesnt' work please help me..i love this dj
It's been a while since I was having this problem, and I no longer have my DJ so this solution is coming out of memory...
Press and hold the play/pause button on the player while you click the reset button with a paperclip or something...
Continue holding the play/pause button until the player restarts into recovery mode (should be under 30 seconds).
From the recovery mode menu you have a couple different options, I would select the option which says something like "find errors" or "scandisk" (I forget exactly what it's called). If it comes up with a scanning progress bar which takes several minutes to complete it's actually scanning the disk; if the progress bar blows through in only a few seconds, and or you hear odd repetitive clicking coming out of the device (or don't hear the whirring of the hard drive at all!!), that's usually a tell-tale sign of a hardware failure of the hard drive.
This is the first and safest option in attempting to recover your player without risking data loss, the next options involve reloading the firmware which can result in data loss, and formatting the disc which will result in data loss but try this option first before doing anything else...
Jul 03, 2009 | Dell Pocket DJ MP3 Player
Dell DJ 30 gig is stuck on recovery mode. Already tried pin hole reset. I don't mind wiping all the music of I just want it to work again
Assuming you simply pushed the reset, you will get only a reboot back to whatever problem you already had. If you hold the play/pause button while briefly pushing the reset, it should boot to the recovery screen. Then try selecting cleanup, then reboot after it finishes.
If its now ok, then great. If not, then do the hold play and reset again, this time selecting format. This WILL wipe all your songs, but may just let it work again afterwards. Worth a try....
Apr 29, 2009 | Dell DJ MP3 Player
Dell dj is non functional
Hold play button while inserting a paperclip into reset opening on dell dj. Release paperclip while still holding play. Recovery mode should come up hopefully.
Dec 25, 2008 | Dell DJ MP3 Player
Did you get your dell dj fixed
its broken dude unfixable. sorry..... your just going to have to get a new mp3. I've tried everything and just threw that stupid piece of technology away.... couldn't even salvage the other parts to fix a cd player
Jul 07, 2008 | Dell DJ MP3 Player
Problem with 'Hardisk Problem'
"Hard-disk Problem"... I'd just like to confirm once more that smacking the player on its rhs while turning it on works.I had to smack it fairly hard though so don't be afraid!! I didn't try smacking it till I checked out the threads above so thanks everyone I'm a happy man again!! :)
or
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
Jan 19, 2008 | Creative Labs Zen Touch MP3 Player
Please Please help
If it kept going to recovery mode that means your device firmware is corrupted...in that case what you can do is to contact dell so they can provide you with the firmare upgrade or you can follow the link below and that should solve the problems you are having...
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R96127&formatcnt=1&libid=0&fileid=124571
If that doesnt solve it you can format your player inside windows media player..NOT MY COMPUTER...and then that should reset the firmware as well..
Thank You
Computerrep
**Please rate accordingly...**
Jan 19, 2008 | Dell DJ MP3 Player
Dell dj mp3
If that doesnt solve it you can format your player inside windows media player1.gif..NOT MY COMPUTER1.gif...and then that should reset the firmware as well..
Thank You
Computerrep
Dell dj player
You can reset it with a paperclip. The reset button is on the bottom. When immediately after you reset, hold the play button and you will get the recovery screen. From there you can reformat(erase everything and start over). That should work. If not, you probably have a bad hard drive.
Aug 10, 2006 | Dell Pocket DJ MP3 Player
Dell DJ MP3 Player Logo
193 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
