Question about Kodak EasyShare V803 Digital Camera
Kodak V803 replacement of LCD screen
Took your advise and got an lcd replacement. Any suggestion or advise on how to get the screws to come out/dislodge from this unit? I'm using a standard (tiny) phillips head screwdriver, but they just keep turning and turning without rising from the unit.
  • kwendell Feb 03, 2009
    Since the screws were soooo small, I put a little nail polish on the tip of the phillips head - - placed the screw on the driver and let the whole thing dry - - walla - out they came. Then I continued to follow "sharcnet's" instructions for LCD replacement and my daugthers camera works as good as new.
    NEW ADD - a covered a piece of hard plastic with a packing material and put in in the carrying case to try to avoid this in the future. THX for your help.
SOURCE: Cracked LCD of Kodak v803
I know people sell replacment LCD for V803 on ebay.
Posted on Jul 16, 2008
t00nz
  • 4738 Answers
SOURCE: LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 16, 2009
SOURCE: Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Posted on Aug 06, 2009
gemmy23
  • 346 Answers
SOURCE: cracked lcd screen on kodak c913, can I find replacement parts?
HI,
I did some checking and you can't repair that yourself. I found this on the net for you:
Thank you for using the Step-by-Step Solutions and Repair Tool. The problem with your product appears to be something you cannot fix yourself. We recommend that you send your product to an authorized Kodak repair center for evaluation. Warranty Coverage
The terms of your warranty are described in your User's Guide. If your product is within the warranty period specified, you must provide a proof of purchase to receive warranty coverage. If you do not provide a proof of purchase, you will be charged for the repair.
NOTE: Warranty coverage does not include products that have been dropped or exposed to liquid. If your product shows evidence of this, your warranty will be void and you will be charged for repairs.
If your product is within the warranty period, having it serviced or altered in any way by a non-authorized party will void the warranty for that repair occurrence.
I am also giving you the link to the main page for Kodak in case you want to send it to them for repair or get more information.
http://www.kodak.com/global/en/service/products/replacementParts.jhtml?camera=C913
Posted on Aug 09, 2009
  • 11967 Answers
SOURCE: Kodak v803 as disk
Use a separate cardreader to download your pictures.
Posted on Aug 25, 2009
Kodak V803 LCD Screen Replacement Problem
Could be a slight misalignment of the ribbon connector- I'd try to reseat it first. Otherwise, you'd have to try it in another known, good camera to know for sure. Not sure if a camera shop could test it, you might call one as a last resort. Good luck!
Mar 13, 2010 | Cameras
Tip
How to replace a defective LCD screen in a Kodak V803 Digital Camera
I just replaced the LCD screen and have a couple of notes. The screwdriver you need is a #00 Phillips tip. There are two lengths screws in the band, keep track of them to reinstall correctly. A magnifying glass is handy so you can actually see what you are taking apart. I had trouble keeping the cable/strap folded correctly while reinstalling, so I used a piece of dental floss to lightly pull on the cable while reassembling and then slid it out as the cases just started to fit together. All relatively painless and the camera now works. I ordered the screen from Kodak for about $51.00 total with delivery and taxes.
on Apr 11, 2010 | Kodak V803 Digital Camera
Tip
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC.
A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00.
To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector.
Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place.
Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard.
Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
on Jan 25, 2008 | Kodak V803 Digital Camera
KODAK EASYSHARE V803 LCD REPLACED!!
you should call KODAK Technical Support thru this number 1800 235 6325 op 12 op 2
Aug 23, 2009 | Kodak V803 Digital Camera
Kodak v803
Hello. We konw someone sell Kodak V803/V1003 LCD on ebay. Please visit the following link or search item number 320277003613 on ebay. Thank you
http://cgi.ebay.com/KODAK-V803-V1003-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320277003613QQihZ011QQcategoryZ64352QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 15, 2008 | Kodak V803 Digital Camera
I think you can start by calling their global office in the Philippines
Kodak Service & Support, Commercial Imaging Group,
Kodak Philippines Ltd
2247 Chino Roces Avenue
Makati City Philippines 1299
(Direct line) 63 2 8431462 and
(trunkline) 63 2 8100331 exts. 210, 201
Fax 63 2 8137907
You can also check malls, I'm sure there will be a center that do repair on kodak digital cameras.
Jun 16, 2008 | Kodak V803 Digital Camera
Problem with the screen
hello. We know someone sell kodak V803 LCD on ebay. You could visit the following link or search the following number on ebay. Thank you.320277003613
Apr 20, 2008 | Kodak V803 Digital Camera
Kodak V803
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Nov 25, 2007 | Kodak V803 Digital Camera
Damaged LCD Screen
The following procedure works on the V1003. It uses the same LCD screen as the V803.
Good Luck!
- Jim
Aug 13, 2007 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare V803 Digital Camera Logo
50 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
