Question about AEG 24 in. Favorit 3A Free-standing Dishwasher
AEG Favorit dishwasher AAA shows Error code 10
And does not complete cycle
  • AEG Master
  • 909 Answers
Normally if washer doesnt complete cycle, its because the element has tripped the over, or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
Aeg 60870 dishwasher water not getting in
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit 88080 service code i30
In my case, it turned out that the faucet was completely clogged with scale deposits. Replacing the faucet solved the problem, so by all means, check this before you take any other action!
Jul 10, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Feb 17, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
Jul 02, 2007 | AEG 24 in. Favorit 40850 Free-standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 3A Free-standing Dishwasher Logo
1,867 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
