Question about AOpen AOH 508 (90.18D10.121) Networking Hub
I'm trying to connect one computer to another using smartftp. how do i find the ip address. i'm using a aopen router model # is aoh-508
    Problem Solver:
  • 8 Answers
Use ipconfig on that pc command prompt
Posted on Mar 18, 2009
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
I cant connect my dell laptop nor detect D-Link dlink Wireless N 150 Router through wifi but my mobile devices can and my desktops can also. please help me able to connect in the internet using wireless...
Try assigning your laptop a static IP. To do this in Windows:
  • Open Windows Start menu.
  • Open Control Panel.
  • Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and thenNetwork Connections.
  • Double-click on your active LAN or Internet connection.
  • Click Properties
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and clickProperties.
  • In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer (try 192.168.1.110 to start). - Subnet mask. Subnet mask used by your router (try 255.255.255.0 to start). - Default gateway. IP address of your router's default gateway (try 192.168.1.1 to start).
  • In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses (or you can try your router's address, probably 192.168.1.1).
  • Click OK.
Source: http://www.hotcomm.com/faq/faq_staticipxp.asp
Please leave feedback for this answer, thanks.
Mar 10, 2011 | D-Link dlinkgo Wireless N 150 Router...
I want to install my D-link wireless
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | Computers & Internet
Can not access router setup page. IP is to be 192.168.1.102 , says can not find. This is the main computer on network, other's are wireless.
The number 192.168.1.102 must be your computer's IP address.If you want to access the router set up then You will need the Ip address of the router.
Is your computer connected to the router with the cable. if not then connect the computer to the router and check the IP address and default gateway on the computer.
Once you have the default gateway number use that number to open the router set up.
Generally the Linksys router IP address is 192.168.1.1.
Try this number.
Click Here for more information about the routers and network
Apr 22, 2010 | Linksys Wireless-G WRT54G Router
I have a D-LINK model DIR-615, my windows 7 computer is saying I am not getting an IP address. My XP computer is hardwired into this same router with no problems. I have switched the ethernet cables,...
For that you need to enable DHCP in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then click on DHCP and enable it.Then save settings and restart router.
Jan 11, 2010 | Computers & Internet
I cannot access an Internet in one of my computers
if you are using dynamic ip address makes sure in that computer that are not connecting has no static ip address, go to my network places and hit propertis, and select tcp ip4 and hit properties, make sure its selected as dynamic not static, if this not working this means, there is cable problem, or network card problem. or try to change the port from the router could be the router port is bad.
Good luck
Mar 19, 2009 | Linksys HomeLink Phoneline (HPRO200)...
Aopen AOH 216 hub
Try plugging the 3 that are not connecting using cat5 and the other 3 wireless
Dec 02, 2008 | AOpen AOH-216 (90.18D10.041)
Need Driver: Aopen Ethernet mini Hub AOH-528
Hi joshua,
1.For a hub you don't need any driver.Just simply plug anything onto it.
2.I think the error message being throw by you computer was
"conflicting IP" not "conflicting ISP" .So if incase of "conflicting IP" that mean you have more than 1 computer using same IP number.So the solution is to change the IP number so that they don't get conflict.
3.make sure you use the same group of IP.like if your first computer is 192.168.0.1 then your second should be 192.168.0.2 and so on...3,.4.,5.....
Bye,takecare.
Apr 11, 2008 | Computers & Internet
Nintendo Wi-fi Connector Problem
nintendo ds should work with most routers it's just the set thats a problem, once the wifi game is in go to wifi connection one settings,then where it says auto obtain ip address click no, then edit,then use an ip address that is the next digit up from your pc or your router eg, if your routers ip address is 192.168.2.1( this is what you would type in your internet browser to get into the router settings), the next digit used by a pc would be 192.168.2.2, so use 192.168.2.3 or above incase you have more than one pc. Next is the subnet mask which should again be as the routers subnet mask which will more than likely be 255.255.255.0., press edit and enter that number Next is the gateway setting, press edit, this is the same number of your routers own ip address as mentioned earlier this is the ip address you type to get into the router eg 192.168.2.1. next is auto obtain DNS, again click no, then on the primary address click edit and again enter your routers own ip address. next is secondary DNS, again click edit and again enter your routers ip address, then click save settings. You should now be able to connect to your router and the wifi connection at nintendo server.
Jun 30, 2007 | AOpen AOR-401M Router
AOpen AOH 508 (90.18D10.121) Networking Hub Logo
110 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
