Question about JVC Audio Players & Recorders
JVC L T11 turntable spins to fast jerry, rigged adapter
I purchased an L T11 table. The power adapter is not the original. Info on adapter is input 120v 60hz 18watt. output is 12vdc 400ma max plug tip is +. class 2. On the back of the table it reads DC 12-14volt. Yhe problem is the table spins way to fast. I tried adjusting the speed with the 33&45 adjustment screws and still can't slow it down enough. Is it possible the adapter is to powerfull causing the table to turn to fast
Where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Posted on Sep 23, 2009
Is it possible to use this turntable from UK 220V 50Hz, in the US 110V 60Hz?
Go to Radio shack or other electronic places and buy the correct converter for it.
May 18, 2015 | Audio Players & Recorders
My JVC turntable has no plug, just a 10-13v lead
Probably as long it produces DC. However you will have to adjust the speed. As the unit was set for a certain voltage which wouldn't change. It will either go fast or slow depending on what the original voltage was. The speed adjuster will either be two presets one for each speed that could be located under the turntable base (covered by a sticker) or on the power board of the deck. Or they might be on the motor itself.
Apr 26, 2014 | JVC AL A158BK Turntable
Connection to PC
you need a stereo male 3.5 plug to female RCAS and connect the turn table to the RCA side and the 3.5 mini stereo plug into the microphone input of the PC
Aug 06, 2013 | JVC AL A158BK Turntable
When plugged in the table does not spin.
Sounds like the belt has come off. Lift the turntable matt it should show you the access hole.
Jul 05, 2010 | JVC AL A158BK Turntable
JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Jun 20, 2009 | JVC Audio Players & Recorders
Table does no rotate
If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
May 18, 2009 | Audio Players & Recorders
Troubleshoot auxiliary equipment
There is no Phono input on your JVC.
What TT are you trying to hook up? If it's a traditional one you would need a preamplifier to boost the tiny signal from the cartridge to a suitable level for the AUX to use.
If you have an old traditional receiver with a Phono section hanging around you could rig something up between it and your JVC.
Plug the TT into Phono on the old receiver. Run RCA cables from any Tape REC output to the AUX. Done.
Jul 12, 2008 | JVC MX-D401T Shelf System
GE turntable microwave Je1540WW 002 Turntable doesn't turn
I have had the turn table motor go defective in microwave ovens.
Normaly, before ordering a new motor, I always checked to make sure that there was power going to the motor assembly. I never had a power drive failure to a motor so-far. When they did not spin, the motor was defective. But, one day there will be a first time for me.
The fix was to purchase a new motor from the manufacture and install it. In some cases, I had to also replace the spindle key because the original broke when trying to remove it when removing the motor assembly.
I suggest that for servicing a microwave oven, you give it out to a service center to have the work done. There are safety issues when working on microwave ovens.
Jerry G.
May 25, 2008 | Microwave Ovens
Suitcase Turntable stopped turning
Check the drive band- it may have come off the pulley. But if it is a new purchase then perhaps it should go back to the vendor
Jul 07, 2007 | Crosley 0187SST Turntable
603 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
