Question about Whirlpool LER7646E Dryer
Burnt Rubber Smell
Homemaker HMCD50Y dyer has a burnt rubber smell evrytime I dry my clothes. I had a tech come and check it out. He said that if the vent at the back of the machine is up against the wall or lint in the vent, it will give a burnt smell. He told me to run the cycle for awhile before using. Nothing he said helps although, I think he was too lazy to find the problem. Please help me. The is new about 6 months and has hardly been used because of this problem. Thank you
  • 640 Answers
Ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Posted on Feb 05, 2009
What could cause the engine to buzz & smell like burnt rubber inside the car
check for failing drive belts and check for a pulley that is running hot or reluctant to spin freely
Aug 06, 2014 | 1998 Toyota Camry
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
Will a failing power steering pump smell like burnt rubber ? One line seems to be leaking but the smell seems wrong.
If the pump is starting to seize up, the belt maybe slipping on the pump pulley, causing the burnt rubber smell.
May 13, 2010 | 1989 Mercury Grand Marquis
Kenmore washer has burnt smell
It's possible that when you replaced the coupler, you didn't exactly line up the holes in the 6 hole rubber piece with the prongs on the transmission and motor.
If they aren't lined up exactly, they can break and rub creating the smell and clicking as the prongs hit each other.
I'd pull the cabinet and check the coupler again.
Oct 28, 2009 | Washing Machines
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
Aug 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Homemaker HMCD50Y dryer
Because the dryer is running, but not heating, it sounds like the element. The rattling could be a part of the element that was weak and then broken during the move.
Inspect the element by taking off the back cover [unplug first] and remove the section of the flue-like piece that goes from bottom toward top at angle. The element is the spiral wire that runs inside that larger aluminum section.
Be sure to remeber where the 6 or 8 wires were connected. Grab a digital camera before removing the wires.
If you need an element, it comes with that aluminum section in a large box--not just the curly wires.
I've seen bad elements with breaks that could only be found by continuity testing and some that are obviously burnt in 2 or more places. I've also seen them ground out by a metal bone from a woman's bra. The move and the rattling--I'd check the element.
You have to remove the vent hose before removing the back cover. Be careful not to damage it. The cover can be a pain to reseat and fit around the vent housing at the same time--depending on work space. With part and tools in hand, 1 1/2 hours for a casual DIYer.
Aug 31, 2008 | Whirlpool LER7646E Dryer
Dryers Logo
562 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
