Question about Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television
Covergence replaced ics, and rz128 and rz129. still opens up those resistors
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please check your solder work with STKs as might be bridge solder in some pins.
Yes. double check for bridged solder or open as well. If everything checked ok, disonnect the related convergence yoke and see if it fixes it (do this very quickly tho). dont let the set run more than a few sec! its a good idea to scope the output too.
gdluck!
mertronics
ca
Posted on Feb 11, 2009
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
My magnavox projection tv has convergence problem.
there are 12 6.8 ohm 1watt resistors in your model. There could be more blown resistors as they often wont show any outward sign of being bad. It could also be the ACS board which is defective if the Resistors are good.
Apr 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue covergence wont work, wavy primary colors
Replace STKs you have 2 of them and 3 resistors near ICs 2.7 ohms.
Feb 01, 2009 | Samsung HCL4715W 47" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Magnovox 51MP3964H17 coverge problem
You will need to replace both STK392-120 convergence ICs and about four of the 6.8 ohm 1 watt resistors. The following link has the replacement ICs and resistors and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Tv repair
Did you check for open resistors coming out of the ICs. These commonly go open when the ICs go out. The are located right next to the ICs there are numerous resitors all with no color bands very easy to locate. Check these resistors.
Feb 02, 2008 | Televison & Video
Prob
Covergence problems . Could be loose contacts on the output IC's or bad IC's . If they are bad they generally also have bad resistors or fuses that open up as well .
Nov 13, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Service Manual PT-51HX41E Needed?
If you haven't the technical ability to repair this set I suggest to get a tech to replace the stk392-110 convergance amp ic's. these ic's are very noticable they have the largest heat sinks in all the sets ic's. but the problem may not be the ic's alone, there may be several resistors open or open pico fuses. So if you are not technicaly inclined donot attempt this repair. it's not just the replacement of the ic's that need be done but geometry and final convergance in the service menu. please leave this to the pros.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
