Lennox furnace not heating up
Have a problem with my furnace, and I hope you can help me. I switch the tstat to call for heat, and the following is what I get ..... 1. The Combustion blower starts. 2. Then I hear a '' CLICK '' 3. There is a long quite moment. 4. The another '' CLICK. '' 5 Finally the main blower turns on, and all we have is cold blowing air. NO HEAT. I never see the Igniters glow, and I only smell a hint of gas. MAKE : LENNOX MODEL:G26Q3-75-1 S/N 5894L37210
    Problem Solver:
  • 17 Answers
Sounds like the ignitor is bad. there shoule be a 2 wire plug going to it. after the inducer motor starts, you can check the voltage at the 2 wire plug located under the burners. you can unpug it to check voltage or you can probe the back side of the plug with a volt meter. if you are getting 120v but it is not glowing, it is bad. you can also ohm it out while it is off.
Posted on Feb 02, 2009
Lennox 80 MGF furnace heat only. Both diagnostic lights are indicating everything is ok with the ignition control but the furnace main fan runs continuously. The fan is on automatic at the stat
So no heating just blower? If you have a g wire on the tstat remove it first. Then possibly a stuck relay. Obviously if the blower stops when g removed the tstat is bad.
Aug 14, 2017 | Heating & Cooling
I have a Lennox furnace. I want to turn on just the fan.
You do that at the tstat. Turn the fan in the on position, not auto.
Jul 19, 2017 | Heating & Cooling
Which color wires do I connect to I- and I+ on my Lennox digital thermostat?
Can you give me more info on the thermostat? Model number maybe or Lennox Elite for example? I have never heard of these I numbers but would like to do some research on it.
Nov 20, 2014 | Hunter Heating & Cooling
Heat....Furnace will not start up worked fine last year it is getting power... I can hear I light hum in the furnace but it will not start it process
If its a high or mid efficiency furnace most of the time the sequence of operation goes as follows: tstat calls for heat (R&W at tstat ) ventor motor starts, pressure switch closes, spark or hsi lights pilot or main burners. main blower motor comes on. From your description of a humming noise it sounds like maybe the ventor motor is seized.
Oct 08, 2012 | Heating & Cooling
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Ruud heat pump high pressure cut off problem
That's going to be in your installer configuration. Check and make sure the G terminal has a wire connected to it at the tstat , and that connection it tight. In the configuration menu, make sure it is set for a heat pump, elected heat. It seems to me that the tstat doesn't know its connected to a heat pump. Should be able to locate aodel # for tstat on the back of it. And ask Mr. Google for a manual, if you don't have 1. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Heating & Cooling Logo
390 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
