Question about Aprilaire 700 Humidifier
Aprilaire pump motor rattles violently
The pump that pumps the condensate out to the sink rattles violently and loudly when it pumps. This started happening a couple weeks ago and has gotten worse as time has gone on. I don't see a way to turn off the pump or disconnect it as it appears to be hardwired into the power supply.
When I pour water into the pump, it seems to be a little quieter when it turns on. Also, there is water that has dripped onto the top of the furnace. I don't see any obvious spots where it is coming from.
    Problem Solver:
  • 11 Answers
You can add bleach in the pump to clean it is probably dirty you may want to do this every 6 months
Posted on Feb 09, 2009
Aprilaire 500 water won't stop running down to condensate pump
Hello, sounds like rhe solenoid valve is stuck open. This will keep water flowing through the humidifier even if the Furnace is off. The solenoid valve will have to be replaced.
Dec 01, 2012 | Humidifiers
Aprilaire 550 not turning on
Hello, apply power directly from transformer to solenoid valve, it it does not turn on the solenoid valve must be replaced. If there is no voltage to the solenoid then follow the wires back and see where there is no voltage.
Nov 18, 2011 | Aprilaire 550 Humidifier
Aprilaire 550 making loud noise - sound like not enough water going through pump?
Hello, check to see that the inlet strainer into the solenoid is clean and no sediment has built up in it, also make sure the outlet of the saddle valve is clear and there is no sediment there.
Feb 14, 2011 | Aprilaire 550 Humidifier
The water basin that receives and pumps out the excess water on my Aprilaire 600 humidifier runs incessantly, even when very little waters in in teh basin? Is there an easy fix? thank you
If you are referring to a condensate pump then the float might be stuck and causing the pump to run continuously. The best thing to do is turn off power to the pump and clean it out and make sure the float is free and not stuck.
Jan 21, 2011 | Aprilaire 600 Humidifier
Aprilaire Humid. Model 560 - not working even though water is on
Make sure the heat is running during test.Does the pump make noise.The control shoud make a soft click when u turn the knob on/off.
Mar 07, 2010 | Humidifiers
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Aprilaire evaporator screen produces a white runoff to the sump pump which clogs causing it to jam. are there uncoded evaporators?
replace the AA#35 water panel annually also try poring a touch of bleach where the pump is the pads have the coating to keep them from rusting you miht be able to find a generic paper model if you look at your local department store
Jul 13, 2009 | Aprilaire 600 Humidifier
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
119 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
