Question about Bose Lifestyle 28 System
I have a loud humm in my bose lifestyle 28 system
My bose system has a loud humm.
  • Anonymous Feb 20, 2009
    I have the same problem, I usually switch between TV and Aux where I have two different input coming in and that sometimes fixs the problem
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Posted on Apr 17, 2009
My Bose Lifestyle 28 is having trouble playing CDs everytime I put a cd it says format unsupported. How do I fix this?
Most likely you have a problem with your CD drive in the Lifestyle system. I suggest to contact Bose, to ask for a repair.
Feb 11, 2015 | Bose Lifestyle 28 System
Bose lifestyle makes loud noise like a build up of
If you still have the speakers that the TV came with hooked up try unhooking the wires to them I had the same problem and it fixed the problem, Good Luck!
Apr 10, 2010 | Bose Lifestyle 28 System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Dec 28, 2008 | Bose Lifestyle 28 System
Loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
Dec 05, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 setup disc
You would have to call 1-800-www-bose they can ship this part for free since you are a bose customer.
Nov 07, 2008 | Bose Lifestyle 28 System
Lifestyle 28 System
All the manuals are available online at Bose web site
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/home_theater_system.jsp
PP
Aug 26, 2008 | Bose Lifestyle 28 System
Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Apr 08, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
506 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
