Question about Microsoft Windows Vista Ultimate Edition
What is bootstraping? - Microsoft Windows Vista Ultimate Edition
    Sniper:
  • 58 Answers
Bootstrapping means
  • "To load and initialise the operating system on a computer"
word comes From "to pull oneself up by one's bootstraps"
Check this detailed explaination at Wikipedia and at Khmere.
Posted on Feb 02, 2009
Bootstraping concept is a loader concept in which loads all process and work of operating system
Posted on Feb 18, 2009
How to reboot
See this image. Reboot is now called 'Restart'. You have to click the little arrow to see the options.
May 03, 2015 | Computers & Internet
Realtek bootstrap selection menu
Check this out:
http://forums.techguy.org/hardware/176404-realtek-bootstrap-selection.html
Nov 28, 2013 | Gigabyte Computers & Internet
How do i get my K/bootstrap/logger.js to work
Looks like a software problem, because this is running on your computer and not in your camera.
Looks like some more people have the same problem. See this link:
Bootstrap.js problem discusion in sencha forum
Nov 10, 2013 | Kodak EasyShare Cameras
File:///F:/bootstrap/logger.js
that file is held on your computer...... nobody can help you unless you post it.
Oct 06, 2013 | Kodak EasyShare Cameras
How do I reset an adtran 908 to factory defaults
Not every router has the button. For Adtran you would need to reload the box and as soon as you see the first prompt wait for "You have 5 seconds to press escape to enter bootstrap mode." In bootstrap you can type "erase startup-config" and hit enter and then answer "y" to "Erase startup-configuration? " and reload.
You also have an option to run "bootstrap#erase file-system" but that will erase all files in the file-system which I don't recommend you do that. Erase startup-config is better.
?I hope that was helpful :)
Sep 24, 2010 | Adtran Total Access 908 Router (4210908L1)
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Code error
first you reset the BIOS remove CMOS battery or shorting it with jumber. this may give solution
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Boot Loop
you may have to reload the OS of the router.
i dont suppose you can kick it into romon mode can you? (usually done by hitting the pause break button on boot.)
if you can you should be able to use Xmodem to reload the OS (as long as you have a copy of it located on your computer)
Mar 11, 2008 | Cisco 1603-R Router
Microsoft Windows Vista Ultimate Edition Logo
144 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
