Question about Vessel Island Glass Sink
Repair chip I have a glass sink with a chip on the inside lip edge. Any ideas on how to fill in the chipped glass?
    Problem Solver:
  • 19 Answers
What you can do is buy a small tube of clear silicone .Dry off the chipped spot completely and apply a very small amount to the hole.make sure to wipe excess silicone asap .let dry for 2 hours and tou should be good to go.
Posted on Feb 03, 2009
My Swanstone sink is sixteen years old and still in very good condition except for a small chip. The sink is a cream color with black and white specks. Is there any way to repair the sink?
You should be able to have a competent repair or restoration specialist from a reputable granite or marble fabrication shop come to your home and fix the problem. If it is a very small chip (less than an eighth of an inch around, my first try would be super glue. Keep in mind the fill will be fairly clear in color, which may match the dark specks, if not use an indelible marker after you smooth the glue to color it black. Use the gel type super glue if it is on a vertical portion of the sink, otherwise use a thinner variety. Clean the chip with sop and water, let it dry then use rubbing alcohol to remove any grease or oil residue. Use a masking type tape to isolate the chip so you have less work once the glue dries. Fill the chip and once the glue is dry, use a single edge razor (Use extreme caution, razors are by nature sharp) to gently scrape, not cut the glue flush to the sink surface. The manufacturers of these sinks claims they are difficult to scratch, but pay attention to your pressure or you might create scratches on the sink itself. Hold the blade perpendicular to the surface of the sink and take your time scraping the dried glue down changing to a fresh blade often. If the chip is in a radius area of the sink, you will have to be a bit more creative and probably use steel wool to remove the excess dried glue. I would start with #000 and see how that works, maybe using #00 to start the process and finish with #000 or #0000 steel wool to match the finish of your sink. If your chip is larger than an eighth of an inch around, I would recommend hiring a repair and restoration specialist from a competent granite fabrication shop to make a color matched epoxy to fill the blemish.
If you have any questions, feel free to contact me, Brandon Wiese - Brandon@StoneRepairman.com - http://www.StoneRepairman.com
Mar 25, 2011 | Swanstone KSDB-3322 Double Bowl Kitchen...
My front load ge washer model GCVH6260F is leaking past the front door. I have examined the seal and it looks fine. Any suggestions.
the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE.
New bellows $150 plus fitting so I use a Bike repair it and used the glue to glue a piece of bicycle tube to the inside of the seal to cover the chip by 1 cm either side and trimmed to the same height as the seal lip.
I then placed a little bathroom sanitized silicon sealant over the repair within the chip, wet down with soapy water on the door glass in the chip area and shut the door. Carefully wipe of any excess with wet finger and repeat. Open the door and let it all cure.
Aug 29, 2010 | GE WSXH208A Front Load Washer
Swanstone sink with chip near the faucet but on the edge near the bowl. ANyway to patch this...a filler so to speak?
Unfortunately Swanstone does not have a repair kit for this type of damage. The chip will be permanant. They do offer a limited lifetime warranty which if a defect is found they will repair or replace at their discretion. Of course you will be responsible for any labour cost as per their warranty and they do not go into any detail on how to repair impact damage. For more information go to www.theswancorp.com
Aug 20, 2010 | Swanstone Home
FRONT DOOR SEAL LEAKING
Jun 22, 2010 | Maytag MAH8700AWM Neptune Front Load...
Leaking door seal
May 19, 2010 | Frigidaire Affinity ATF7000E Front Load...
Leaking water at the front by door
May 17, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Washer is leaking water beteen door and seal
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My glass cooktop has a chip on the top edge. Is there something I could fill in the chip with?
most hardware stores and some parts stores sell a special bake lite enamel paint the repair chips and cracks with on appliances
Jan 20, 2010 | Kitchen Ranges
Have observed H2O leaking from front of machine out of door.????and door lid is closed , it will not go if open. There is a tiny chuk out of the rubber and unsure if the rubber part that is around the...
  • Hi,
  • Try these
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
Please rate my suggestion...
Apr 14, 2009 | Washing Machines
Small chip in granite countertop
Well you should seal your granite counter at least once every two years because granite is pourus. Theres something called Granite Guard you can use to seal your counters and other different sealers as well. You can pick some up at your local home and garden supply store.
Apr 02, 2009 | Stone TOP ONLY: 21 in Black Granite Vanity...
Vessel Island Glass  Sink Logo
636 people viewed this question
Top Vessel Home Experts
Donni Steen
Tom Chichester
Are you a Vessel Home Expert? Answer questions, earn points and help others
