Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a Whirlpool refrigerator that defrosts intermittently ( works fine for a month and then ice builds up).. I have replaced the thermostat, defrost timer and the heating rod seems ok.. This is driving me nuts..the intermittent nature of this problem..
  • 2 more comments
  • lzc9pk Feb 03, 2009
    JT
    Thanks,
    Sorry.. I did not change the heater .. I had only changed the defrost timer & thermostat,, Having said that ... does your suggestion still hold good... pls let me know
    PS
    JT
    Sorry for the long e-mail..
    Yes I had verified after manually turning the defrost timer I see the water dripping in the fridge compartment.. this probarbly means the heater is working fine and that the drain ipe has solidified and water is draining in the fridge from the freezer. I could manually defrost and things will be fine for approximate 4 weeks..
    Fyi - during when things are working fine I can force the defrost cycle and can see the water dripping in the pan...
    It seems the pipe freezes after 3 -4 weeks..So that is why I thought ( 3 months ago) there was a problem with the defrost timer so I replaced that, That did not fix the issue so I replaced the thermostat...The intermittent nature is what is making this tough ...I have not tried ur earlier suggestion of tightening the wire onnections.
    JT
  • lzc9pk Feb 04, 2009
    Yes This is what I was thinking...let me know what you come up with
    Thanks a bunch
  • GE Master
  • 4,636 Answers
When you replace the heating elements did you see burn marks on the wire connecting to elements? I had the same problem and until the wire conections were cleaned replaced tightly it did as your symptoms. Let me know and I will help you through this.
JT
Posted on Feb 03, 2009
  • John Tripp
    John Tripp Feb 03, 2009
    OK the defrost timer should cycle on about every 8 hours. Manually turn the timer slowly clockwise until you hear the refrigerator compressor stops. Silence for about 1 minute and then the sound of crackling should be heard inside the freezer. That sound tells you the element is heating up and beginning the thaw of the evaporator coils. This also can be checked with an amp probe but that is another story.
    Tell me if you hear or see changes in the freezer compartment and we will know our next step. I look for your next post...JT
  • John Tripp
    John Tripp Feb 04, 2009
    OK, now we are going in the right direction I have seen where people had clogged condensate drains related to the water freezing in the drain opening itself and needed to install kits to assist the defrost of the ice slug in the drain before the thing did what it was supposed to do. I will post and try to find the chat threads and find answers. You try to talk to a local GE supplier and ask if they recall such a kit for the recent explanation of the detailed problem. JT
I have this Refrigerator, Whirlpool GS6SHAXMQ Side by Side and the chill side does not cool.No alarm and freezer side is fine.
Although the freezer size seems to be fine, it is probably the problem! All the cooling comes from the freezer side into the chill side. So first make sure that the fan is operating, so that cold air is blown into the fresh food side. Then check the ice build up on the evaporator coils (behind shield in the upper section of the freezer). If there is a lot of ice, maual defrost it by unplugging from power and using a hair dryer or heat gun - make sure you are ready to deal with all the water! The ice build up is caused by a failure of the defrost circuit which is made up of the defrost heater, defrost thermostat and a defrost timer that is part of the control board on your unit.
Hope this helps!
Hal aka ImJustAvg
Jan 02, 2012 | Whirlpool GS6SHAXMQ Side by Side...
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Hi my freezer is freezing intermittently. For example, it will freeze the ice cream and then the next day the ice crease is soft. it may go two days working fine and then back to the same problem again...
Hi, The defrost timer is sticking on sometimes...replace it..
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Whirlpool GD5SHAX Side by Side...
I have a whirlpool refrigerator model #GT15HTYMQ81
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The defrost timer The defrost thermostat (also called the bi-metal switch)
Aug 21, 2011 | Whirlpool GT1SHTXM Top Freezer...
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up on back wall of freezer
You need to replace the heating elements and defrost timer relay. Had same thing as you 6 months ago. The lower one is probaly blown but replace all 3 parts or youll continue to have problems.
Jun 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator is not defrosting right..whirlpool ref..
is it frost or ice.if frost you will need an ohm meter to check continouty on the heaters and term thermostat.term thermo must be cold to check.if ther ok check voltage to the heater system from the defrost timer.if no voltage replace timer.if its ice it could be a blocked defrost drain.unblock clean out
Dec 31, 2008 | Whirlpool GD2SHGX Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
141 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
