Question about Mitsubishi WS-65809 65" Rear Projection Television
Have a mitsubishi 1080 series tv
My tv dosnt have an hdmi input, is it not possible to use an upconverter with my tv
  • Anonymous Feb 10, 2009
    I need the hdmi port also
I am not able to assist you with your problem with your tv, but if you get a point where you decide to get rid of this tv for parts then i would love the chance to get this tv from you as i need the lense out of the front of this model tv for my application. please contact me via email at mrshadetree0222@aol.com, and or via telephone at 304-937-2369 thank you have a great day!
Posted on Feb 16, 2009
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a mitsubishi medallion 1080 series hdtv. I can't figure out how to switch it from cable tv to a screen I can play my x-box game on.
you should have a button on the remote marked input or source or comp or HDMI one of those should fix it just go to the input that your xbox is connected to
Dec 04, 2010 | Televison & Video
There is only one 1080 connection in the back of this tv. I have my cable box and blue ray dvd player that need to hook to 1080
If you are referring to an HDMI input. you can buy a HDMI switch and be able to select many different sources. start by searching for an HDMI switch on Google
Dec 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Dec 01, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Upgrading my 480 component input to 1080
Get an upconverting DVDP that puts out 1080i on component. They were made several years ago, and today it can't be done without HDMI, which your set is too old for.
Momitsu, Bravo, Lite0n made them, with the Samsung 841 hackable for that purpose. Try to find one used, and be sure to ask whether they upconvert SD - standard - DVDs from 480i->1080i before you buy. Then take that 1080i in via component, which is stellar in its performance and has none of the anomalies that are plaguing HDMI on many brands of CRT units.
Mr Bob
Feb 04, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Mitsubishi WS-65809 65" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
