Question about Sharp EL-1197P Calculator
Top row buttons on Sharp EL-1197P Calculator not working.
I took my Sharp EL-1197P apart and cleaned all the buttons, rubber pads, etc. I did a good job, but now the top row buttons, (print, ((although some print functions work such as the #/ key, but does not print each key stroke as should)), Rate, K - A, 5/4, F63210) do not work. I think it has something to do with the clear plastic piece that goes over those buttons inside, before the rubber pad goes back on. I don't know if it goes under, in-between, or on top of the rubber pad. Can you help me restore these functions ? Otherwise, it's as good as a brand new machine. Thanks. Bill
5 Suggested Answers
SOURCE: problems with my calculator sharp el-1197p
If the top button, third from the left is set to K it acts like a calculator. If you push it over to A it acts like an adding machine.
For an adding machine: type the number first then hit the function (i.e. +, -, x,...)
Posted on Feb 20, 2008
freetek
  • 5568 Answers
SOURCE: sharp elsimate EL 2125E calculator
Lokks like it's available for download in several places; here's one:
http://esupport.sharp.hu/html/om/DataOutputDetail.php?TemplateLang=en&ID=2578
Posted on Apr 22, 2008
  • 20 Answers
SOURCE: cant load tape
You probably have some paper scraps stuck in the path that the paper has to go thru.
Posted on May 07, 2009
Jimsta01
  • 405 Answers
SOURCE: how to change date and time
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 07, 2010
  • 102366 Answers
SOURCE: need manual for sharp calculator model el-1197p
http://www.sharpusa.com/~/media/3F4ED1815067459995912CEE6A6A6DCB.ashx?cal_man_el1197P.pdf
Posted on May 25, 2010
Can my calculator be fixed if water has been spilt on it??
Trey taking it apart and drying it. Use cans of compressed air , if necessary. Put it out in the sun, all day, to dry. If this does not work,
something got fried. These procedures need to be done BEFORE turning it back on.
Jun 24, 2014 | Sharp EL-1197P Calculator
HOW TO CHANGE RIBBON
how do I change the ribbon on my sharp EL-1197P calculator?
Aug 20, 2010 | Sharp EL-1197P Calculator
Need manual for sharp calculator model el-1197p
You can download the required manual from:
http://www.retrevo.com/support/Sharp-EL-1197P-Calculators-manual/id/358bh050/t/2/
On the page which opens, click on GET MANUAL button and follow the instructions on next page to download the manual.
Hope this solves your problem. Thanks.
Sep 19, 2009 | Sharp EL-1197P Calculator
Cant load tape
May 07, 2009 | Sharp EL-1197P Calculator
How do I set the date and time on the EL 1197P III
Mar 13, 2009 | Sharp EL-1197P Calculator
Sharp el-1197p3
push and release reset button many time while you apply dry contact cleaner on the button- remove the power and return it twice.
Feb 12, 2008 | Sharp EL-1197P Calculator
Problems with my calculator sharp el-1197p
Sharp EL-1197P Calculator Logo
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
