I have a samsung B1245S washing machine error 53
  • 15,935 Answers
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Samsung B1245s coming up with fault tE which isnt in the book, it wont let me do anything even turning it off and trying to restart it still comes up, near the beginning of the cycle
    Samsungs 'tE' stands for 'Thermistor Error', also refered to by other manufacturers as the 'NTC'.???
    'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
    One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a couple of boiling kettles into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Sep 19, 2011 | Washing Machines
    Samsung front load 6.5kg four year old , not working properly,stucking after sometime code as 53,what is the problem pls help.can i know what this sign means i.e, 53.can i see online list of problems...
    i think that is a code that represent some problem with your washing machine. it maybe cause by mechanical problem or sensor hence it send a signal to its IC system control that there's something wrong.
    Jan 29, 2011 | Washing Machines
    I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
    Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    Dec 17, 2010 | Samsung Washing Machines
    Switched timer to 53 mins. Machine runs with water trickling instead of gushing. It runs down slowly to 40 mins and then shows 4W (which is Error)
    sounds like a bad inlet valve or screens inside the inlet valve are dirty, the valve is located wher the fill hoses hook up at
    Nov 18, 2010 | Samsung Washing Machines
    Samsung washing machine b1245s makes a grinding noise but wont spin...any ideas why and how to fix the problem?
    i would grab a towel and check the pump for grit
    and things that dont belong
    may not be the actual problem but thats whered id start
    have a great day
    Oct 09, 2009 | Samsung B1245 Front Load Washer
    Samsung smart wash B1245S SE error
    you need to drain the washing machine by removing the little door below the drum door and pll out the the hose with a white knob (beware alot of water comes out so have a couple of pans ready. the fault means that there may be a blockage in the debris filter (next to the outlet hose yuo just pulled out) am sure you have prob already discovered the fix by now though!
    Jan 12, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Samsung b1245s washing machine
    The error code HE2= water heater error (The heater element did not getting hot)
    Unplug the machine to reset this error.
    Try different cycle let see you still getting the same error.
    May 07, 2008 | Samsung WF337AA Front Load Washer
    My samsung smart wash b1245S 6kg washes but won't spin, it displays an EU message on digital display, what is wrong ???
    its your drain pump
    must be a common problem on this machine. i have had to change the pump 4 times now in the 4 years i have had it.
    they are about £8 off ebay including the postage
    Apr 14, 2008 | Washing Machines
    Samsung smart wash b1245s doesn t work
    motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
    Oct 13, 2007 | Washing Machines
    Washing Machines Logo
    345 people viewed this question
    Top Washing Machines Experts
