Question about Ovens
Oven comes on then beeps and a code F4 comes on
It was working fine no problems then started beeping and a F4 appered on the screen
  • rick1247 Feb 02, 2009
    F-2 or F-4 appears on the oven with a continuous beep. What is the problem?
How do I solve a F4 problem in the Decor electric stove?
Posted on Nov 22, 2009
Dacor booklet indicates F4 is an open circuit in the oven temperature sensor.
F2 indicated the oven temperature exceeded the clean runaway temperature (Self Clean mode only) or the cooking runaway temperature (cooking mode only).
Posted on Feb 03, 2009
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
The oven keeps beeping code F4.
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Amana AOCS3040 Electric Single Oven
When baking in top oven for any period of time my oven will start beeping with an F4 blinking on the oven temp screen? What is it trying to tell me?
Hello & Welcome to FixYa
F4 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. However, I believe it is the sensor as the problem is only with bottom oven. Please get back to me if you have any other questions.
Kevin
May 03, 2011 | Ovens
My oven comes on and reaches the right temperature but then it starts beeping and shows F-2 or an F-4 in the display window. Then it stopps cooking.
Your temperature sensor is inside the oven in the top rear section. It is metal about 3 inches long. You can remove it from inside the oven. The F2 and F4 codes is a bad temp sensor.
Nov 24, 2009 | Maytag CWG3100A Gas Single Oven
F4 comes up on my stove, keeps beeping what to do
Sorry to say you will need an engineer to check the heat sensors as they may be faulty
Sep 21, 2009 | GE Ovens
I am getting a F4 code and beeping. The beeping
Replace the oven temperature sensor. It is located in the back wall of the oven. 4-6 inches long,up high on the right or left side depending on model. Most can be changed from inside the oven rather than through the back.
Sep 02, 2009 | Kenmore Ovens
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
F4 - what is it?
f4 means it has a shorted oven temp. sensor and will need to be replaced.
Nov 19, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
531 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
